72 powersteering gear on a 64 f100????
Whats up people i am brand new to this community and im gana need lots of help. I have a 64 ford f100 step side and a 65 f100 with twin Ibeams. the 64 does not have no steering column nor gear, but the 65 ive instaled a 72 ford steering gear for power steering. now im gana use the 65 as parts because of to much rust. is it possible to put the column and power steering gear on the 64 because the 64 has leafs. help please.
First and Foremost, Welcome to FTE:
Made the upgrade on 65 F100 and as you noted it's pretty much a direct swap with 72-79 Ford pickups. Not familiar with the 64 chassis setup, wonder if upgrade on straight axle would be simular to installing p/s in a 4X4. Came across an article ' intigrating power steering for Ford 67-72 4wd', may be worth checking out. The article is in another Ford truck forum and would need to run a search "the 67-72 Ford Pickup Resource" , go to the home page with the list of articles. Certain more experienced member on topic can provide current info, again welcome to FTE!!!
dave
dave
If you get stumped using donor parts, this vendor, www.gearheadsnd.com, has everything you'll need to add PS if you have a Y block in your truck...I'm about to do this with my own '64 and sourced it from them...it's not cheap, though.
I`ve thought about PS for my `62. The boxes on the `65 up trucks do not look like they will swap. Of course anything can be adapted to work, but it may require some major mods.
I`ve been tossing around the idea of using a rack-n-pinion with my straight axle. Just fabricate some mounting brackets onto the axle and use steering u-joints to connect column, mount a ps pump on the engine and voila !
Why wouldn`t this work ?
You may want to also check it out. Runs about $600.
<table x:str="" style="border-collapse: collapse; width: 613pt;" border="0" cellpadding="0" cellspacing="0" width="818"><col style="width: 613pt;" width="818"><col> <tbody><tr><td class="xl24" style="height: 13.2pt; width: 613pt;" height="18" width="818">
</td> </tr></tbody><tbody><tr style="height: 13.2pt;" height="18"></tr></tbody></table><table x:str="" style="border-collapse: collapse; width: 613pt;" border="0" cellpadding="0" cellspacing="0" width="818"><col style="width: 613pt;" width="818"><col> <tbody><tr><td class="xl24" style="height: 13.2pt; width: 613pt;" height="18" width="818">
</td></tr></tbody><tbody><tr style="height: 13.2pt;" height="18"></tr></tbody></table>
ok i understand but the 72 box will not work on the 64 because the gear box mounts inside the frame and behind the front axle so you will have to find something in the aftermarket but it wont be cheap you can check old threads and classic truck sights
also i still have the complete manual box and column out my 64 if you need any of the pieces let me know
Originally Posted by gritsngumbo
FYI: No Limit Engineering has something similar to what you're talking about: http://www.nolimit.net/prodinfo.asp?number=PS%2DSA%2D
<TABLE style="WIDTH: 613pt; BORDER-COLLAPSE: collapse" cellSpacing=0 cellPadding=0 width=818 border=0 x:str=""><COLGROUP><COL style="WIDTH: 613pt" width=818><COL><TBODY><TR><TD class=xl24 style="WIDTH: 613pt; HEIGHT: 13.2pt" width=818 height=18>
</TD></TR></TBODY><TBODY><TR style="HEIGHT: 13.2pt" height=18></TR></TBODY></TABLE><TABLE style="WIDTH: 613pt; BORDER-COLLAPSE: collapse" cellSpacing=0 cellPadding=0 width=818 border=0 x:str=""><COLGROUP><COL style="WIDTH: 613pt" width=818><COL><TBODY><TR><TD class=xl24 style="WIDTH: 613pt; HEIGHT: 13.2pt" width=818 height=18>
I am a fabricator. I`ll build my own kit.
