How long do the glow plugs run?
When the "Wait to start" light goes out does the actually mean that the glow plugs have turned off or are they still on? What I'm getting at, is whether or not it's truly necessary to sit there and turn the key on and off and on and off in the mornings or can I just turn the key to start and leave it in that position for a minute, then start the truck?
Some have added a light to the dash that goes to the glowplug side of the GPR and timed it at around 2 minutes, I believe. I have not added my light yet but plan on it soon. I have let the glow plugs cycle for the 2 minutes before I crank her over and at -5F( -15F windchill) after sitting for 8 hours, she starts right up. At my part-time job I can't plug in, so this method has worked really well for me.
on
the time span depends on the temp...you can add a light..it is very simple..just read this link..
https://www.ford-trucks.com/forums/6...cator-led.html
on
I solved the problem of knowing when the GPR kicks on and off by buying a volt meter that plugs into the cigarette lighter. The voltage will read about 11 volts when the GPR is on. Even after the engine starts, the voltage will still stay around 11 volts until the end of the cycle.. about 1 minute, depending on the temperature.. I leave the meter plugged in all the time.. Also, you can keep a eye on the alternator voltage.. which is around 14.4 volts.. See:
http://www.cetsolar.com/voltmeter.htm
Originally Posted by viperbluelx
Cool, so me turning the key on and off like and idiot everytime the wait to start light goes off isn't serving any purpose really, lol.
drylakemachine
04-05-2017 11:49 AM
stickandtin
02-02-2016 06:34 PM
CaptainFacePunch
13
08-13-2015 03:38 PM
