Grinding noise....??
#76
As you sped up the vacuum pressure changed (normal). The re-occurance of the grinding at that time indicates there is still a leak somewhere in the 4x4 vacuum lines, or a bad IWE internal seal. Have you checked the two (one way air flow) check valves? They are often overlooked when trouble shooting.
pablocruz69
1997-2006 Expedition & Navigator
11-16-2015 09:37 PM
shaferz
01-28-2012 10:45 PM
