No fire until key is let off after cranking
I have an 85 F150 that will not start. I took the coil wire off and put a sparkplug in and it only sparks (one spark) when I let off the key after cranking. I have replaced the ignition switch, ignition control module, solenoid, and the coil. Has anyone experienced this or know what might correct the problem? The truck is getting fuel like it should, just no spark while cranking.
When you say you replaced the ignition switch, do you mean the switch at the bottom of the steering column? That would be my first guess at what the problem is. The replacement switches come with a pin to hold them in the locked position. After adjusting the switch location you must remove the lock pin. If you have already done that then my guess would be either a bad ignition switch or it is out of adjustment. Hope this helps. This is a pretty common problem with that year truck but a new switch usually takes care of the problem. Gil
Originally Posted by cr506
as i said, that problem seems to be fixed but now I have a problem with the truck bogging down when I press the gas pedal. I can let it idle or I can floor it wide open and it will go but normal driving it bogs down. Could this be a timing issue or more likely a fuel issue?
It wouldn't hurt to check that on yours.
I am in the middle of the TFI to DS2 swap and am having the same problem. I am using the TFI coil. I have power to the coil during crank and run. Pickup coil in the distributor is brand new. Coil and ignition obviously are good, as I drove it into the garage. Swapped the ICM off of the wife's Bronc and have the same condition. I would have swore the pickup coil was bad, so I replaced it. Again, the only spark I have is when you let off of the key. Any ideas?
Check all the wires and connector pins in the harness between distributor and module and coil, especially the grounds, for an open circuit. A broken wire right at the back of a connector pin is fairly common. Use the old pull and wiggle test. Also make sure none of the wires are rubbing against the engine block or other ground.
