Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460)
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 04-26-2002, 10:41 AM
1986f150 1986f150 is offline
Garage is empty, add now
1986f150 is starting off with a positive reputation.
Post SPECS FOR AN 1975 460
ok i just bought a rebuilt 460 the guy says it cmoe out of an 1975 thunderbird i was wondering the output for it is the number on the intake says DOVE - 9425B and the heads say D3VE - A2A someone please let me know the output and what year it is
  #2 (permalink)
Old 04-26-2002, 04:36 PM
DeGideo DeGideo is offline
DeGideo is starting off with a positive reputation.
[updated:LAST EDITED ON 26-Apr-02 AT 05:45 PM (EST)]The source book I'm looking at says the 1975 460 has 8.0:1 compression,and has 218(net)horsepower@4,000rpm.the D3VE-A2A heads are listed as '72-'74 year cylinder heads.Combustion chamber volume is 91.4cc,the intake valves are 2.08",and the exhaust valves are 1.66".The only difference listed between the '72-'74 heads&the D4VE '75-'78 year heads is the '75-'78 heads' combustion chamber volume is 96.2cc.
  #3 (permalink)
Old 04-26-2002, 09:28 PM
what about torque
  #4 (permalink)
Old 04-27-2002, 05:28 AM
357 lbs./ft. @2,400 rpm.Another source book listed the 460 as having 365 lbs./ft.@2,600rpm.
  #5 (permalink)
Old 04-27-2002, 09:51 AM
ok you say the the heads are 72 74 i just found out that it is an 1973 what are the horse power and torgue specs for it because the 75 have 96.2cc and the 73 has 91.4 there should be a difference in output please tell and what it the compression ratio and are the valves bigger
  #6 (permalink)
Old 04-27-2002, 06:36 PM
If the 460 engine you have is a 1973 year engine,it must have originally come in a Lincoln.The 460 wasn't offered in the Thunderbird until 1974 model year.The 429 was the 1973 T-bird big-block.One of two things:either it came out of a '73 year Lincoln,or it was rebuilt,and stroked from 429 to 460cid.The 1973 heads have the same valve sizes:2.08"intake,1.66"exhaust as the later heads.A 1973 460 is listed as having the same compression ratio(8.0:1),and horsepower is listed at 219@4,400rpm.Torque is listed at 357 lbs./ft.@2,200rpm.Basically,the 460 engines found in '72-'78 cars had the same(or close to it)horsepower&torque ratings.In contrast,the 1973 429 was listed at 201 horsepower@4,400rpm.It also had 8.0:1 compression.Starting in 1972,Ford used net horsepower ratings for it's engines.
  #7 (permalink)
Old 04-28-2002, 03:27 PM
mike460's Avatar
mike460 mike460 is offline
mike460 is starting off with a positive reputation.
__________________
88 F150
351 Windsor, Performer RPM Heads, Trick Flow R Intake, Lunati 51025 Cam, Comp Pro Magnum 1.6 Rockers, Hedman Headers, Custom Exhaust
http://www.youtube.com/watch?v=w3uQx7WVuVA
  #8 (permalink)
Old 05-09-2008, 08:13 PM
sksfreak sksfreak is offline
sksfreak is starting off with a positive reputation.
The D0VE part of your vin means that it is a 1970 model block. (the D stands for the the 1970-1979 decade like C stands for the 1960-1969 decade. The 0 stands for the year, 1970.) If it was out of a 1975 thunderbird the vin would be D5VE. The heads are from a 1973 model engine.
  #9 (permalink)
Old 05-09-2008, 11:59 PM
Dirt racer's Avatar
Dirt racer Dirt racer is offline
Dirt racer is starting off with a positive reputation.
Actually in a 73 tbird you could get a 429 or a 460. I have a 73 tbird that I have owned since 85 and it still has its original 460. 73 was the first year for it though in the tbird.
Tags
1973, 1975, 429, 460, 73, 75, compression, extra, f250, ford, horsepower, model, ratio, spec, specs, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
