FIPL quirk
FIPL quirk
Ok, with the help of others from another site I have found that my FIPL is not operating like it should.
The FIPL is way off the specs that it should be. Using the middle wire on the FIPL I have set it to idle at 1.2 volts, yet at wide open throttle it is reading 7.8 volts when it should be closer to 4.5 volts. Has anyone had a similiar problem?
Also, the Orange/White wire on the FIPL has no reading when it should have 5 volts. The Black/white wire is reading 11 volts when it should be .025 volts.
any thoughts?
Thad
any thoughts?
Thad
Originally Posted by ford trans tech
there should be no more than 5 volts present if so there is a short to vehicle power somewhere or the pcm,s referrence voltage circuit is damaged , also check your ground wire there and see if it has continuity to ground or is open
there are three wires , one is VREF (referrence voltage ) it should read 5 volts , teh second wire is signal return , the third is ground , the fipl works by changing the resistance and grounding vref voltage through the potentiometer thus changing it from about 1.0 volt at idle to about 4 volts at full throttle , the ground wire should be black in color and should have no resistance to ground in it , the Vref wire should have only 5.0 volts present if there is more go to the PCM connector behind the left inner fender apron and remove the connector it is retained by one bolt with a 10mm head find the matching wire color and check it there for continuity and also for any voltage with the key on , there should be no voltage present with teh pcm disconnected if so there is a short to power somewhere the easiest repair would be to overlay the circuit and not a bad idea due to the age of the wiring , by this i mean you disconnect the original wires near the fipl and the pcm and add new wires bypassing the old ones . if you have more than 5 volts you need to find the source if it is there with the pcm disconnected ggod luck
you need to check only the three wires at the fipl one is ground the other is signal return and the third is referrence voltage it should have 5.0 volts
Vref= 0 volts
Signal wire= 1.1 to 7.8 volts (idle to WOT)
Ground= 11 volts
Thanks, why I have moved on to try other solutions!!!
Thad
