cranking torsion bars
crawl under the truck and look about - under the front seats. the torsoion bar is tow rods that come from the fron wheel a-frame to the cam under the seat on the frame. there is no coil spring on this truck, the torsion is a twisted hex rod. you can see a screw on each cam pointed down toward the ground. you can turn them inward and lift the truck maybe 1 inch. their purpose is to levle the truck side to side and front to back. it really does not change the loading as you raise and lower. thing about it, the truck weight has not changed, as you push on the screw, the truck goes up. raising or lowering has no ill effects.
i leveled mine on saturday in my friends garage. i measured from the ground to the top of the wheel well and it was 37 in the front and 38 1/2 in the back. when i was done it was 38 1/2 all the way around. i love the new stance of my truck and the way it rides. and i also took the step bars off so it looks 4 inches taller.
Measure, the lift the front of the truck, turn them, then let it down and drive around for a few miles them measure again, you may need to do this a couple times until you get the right height.
it is an 18mm bolt
there are some ill effects to doing this your bars will start to saggggg
so for a few months you will have an inch lift then a half inch
then it will be back to stock
you will need to aling your truck after doing this mod or you will screw up your tires
i cranked up mine and they snapped both of them came un****ed not a fun ride so my recomendation is save some coin and buy a lift kit
it is an 18mm bolt
you had other problems then. i had a 99 with them cranked all the way up for 2 yrs sold it to a friend still the same way with no problems what so ever. except alittle less wheel travel but normal driving i never noticed any difference
