1994 Ranger and OBD II compatiblity
Old 01-09-2008, 12:19 PM
Skarr's Avatar
Skarr
Skarr is offline
Greetings!
Is the 1994 Ranger fully compliant or partially compliant with the OBD II protocol? I've seen various information stating that 1994 might have been a transition year for OBD II and therefore some or all of the data may not be accessible through OBD II. I think model year 1996 was the year that all cars were required to use OBD II, but 1994 and 1995 are a little fuzzy.
Is OBD I the precursor to OBD II? And would a 1994 Ranger use OBD I codes?
Finally, will an OBD II scanner read OBD I codes?
Thanks!
Old 01-09-2008, 12:29 PM
RangerPilot's Avatar
RangerPilot
RangerPilot is offline
'94 is OBD-I, or rather, EEC-IV
'95 was a transition year, you could get either EEC-IV or OBD-II in the Ranger.
'96, OBD-II was required
OBD-I/EEC-IV is the precursor to OBD-II, yes.
A '94 Ranger uses OBD-I/EEC-IV codes.
Most OBD-II scanners will not read EEC-IV codes without some sort of adaptor, and even then only the high end ones. But EEC-IV scanners are cheap and easy to find.
Old 01-09-2008, 01:02 PM
Skarr's Avatar
Skarr
Skarr is offline
Thanks, RP!
mike21105
09-08-2016 02:18 PM
XFORMR
12-08-2015 07:33 AM
bbaudoin
6.7L Power Stroke Diesel
04-02-2015 12:00 AM
kountzecobra
06-05-2014 10:16 PM
FlatlanderKW
08-04-2010 04:18 PM
Quick Reply: 1994 Ranger and OBD II compatiblity
