all info on a 300/6 engine swap
i have a '94 f150 2wd w/ a 300 I6 and have just decided to swap in a new engine. I want to find a 460 or something else with roughly the same power or more that will most easily fit the swap w/ easiest mods. ANY info would be helpful on changes i will have to make like bellhousing, tranny, motor mounts, gears, rad., etc. what would be the best place to look for info on prices of engines, mods, and parts.
thanks for the help, greatly appreciated
If you use a 289,302,351windsor,or 351 cleveland,You can use the same trans they have the same bolt pattern on the bellhousing as the 300.
78 F150 4x4
429 CID
Dana 44 spooled Front,
9"Locked rear,
5:13 Gears
17/40/15 Gumbo monster mudders
18/39.5/15 Swamper Boggers
BIG,BAD,and UGLY.
scottjohn
10-20-2002 12:47 PM
