Rusted Front Coil Spring Towers
Old 01-06-2008, 06:11 AM
SiverFox's Avatar
SiverFox
SiverFox is offline
Question Rusted Front Coil Spring Towers
I have a 1995 f-150 4x4 4.9 5spd. The front coil spring towers are rusted through. This is the part of the frame that the coil spring and shock attaches too. It is part of the frame. What is the correct name for this part and can it be replaced? If so do you have a supplier?
Thanks.
Old 01-06-2008, 06:35 AM
alz's Avatar
alz
alz is offline
You have the correct name. Yes, they can be replaced. You will have to remove the rivots(drill, grinder, air chisel). Just replace with grade 8 hardware.
Also, be aware there is a brake hose that runs through the bracket. It is held tight with a spring clip(dealer only item).
BroncoGraveyard has replacement towers as well as your local dealer. My dealer was actually a little cheaper, but needed to special order parts. So, I got them from BroncoGraveyard as they are local to me, about $100 per side.
Might as well replace the rubber brake hose while you have it all apart for good measure.
Let me know if you have anymore questions.
Old 01-06-2008, 06:46 AM
SiverFox's Avatar
SiverFox
SiverFox is offline
Thanks ALZ for the quick reply. I'm not crazy about going to the dealer and never thought of the bronco graveyard. I'm going to look now.
Old 01-06-2008, 06:58 AM
Mr Jimi's Avatar
Mr Jimi
Mr Jimi is offline
I have heard these called
shock towers
Jim
Old 01-06-2008, 07:02 AM
JLDickmon's Avatar
JLDickmon
JLDickmon is offline
or spring perches
anyway, Ford still produces them as a replacement part, and they're really not that overly hard to do..
a spring compressor would be a good tool to rent from NAPA or Auto Stoned...
Old 01-06-2008, 01:45 PM
alz's Avatar
alz
alz is offline
Spring compressor not really needed on these trucks. Lift the truck by frame. Remove the shock and the axle should drop enough to remove the spring. You may have to put a little weight on it, but definitely enough room.
Old 01-06-2008, 06:59 PM
lostin90s's Avatar
lostin90s
lostin90s is offline
No compressor needed. There was a post that this is no longer a dealer part. Bronco Graveyard had them . They r of the dual shock type.
Spring housing R EOTZ 5A306 E
R EOTZ 5A306 J
Old 01-07-2008, 08:35 AM
aj197816134's Avatar
aj197816134
aj197816134 is offline
They are available from dealers still. There was a post about a month ago that had alot of good discussion. My local FORD dealer was able to get them in 2 days I recall, maybe one. If they can only get the "dual shock" design they will work just fine, even if you have the single application.
If you need any help or pointers post or PM me.
Definetly replace the following:
Tower (duh)
Rubber brake Line
Shocks
USE GRADE 8 HARDWARE
Anything else you do, is up to your as you see fit, shouldnt take long at all
Old 05-25-2011, 05:18 PM
dirtyfordtruck's Avatar
dirtyfordtruck
dirtyfordtruck is offline
Just ordered a coil tower from my local ford dealer for $68 and tax for my 1995 F150 4wd. The coil tower is a special order part and will be delived in 2 days.
R EOTZ 5A306 J
Old 05-25-2011, 05:41 PM
bent-1's Avatar
bent-1
bent-1 is offline
Old 12-16-2013, 04:38 PM
dieselpower4x4's Avatar
dieselpower4x4
dieselpower4x4 is offline
answer to your question
Thanks.
those are front coil mounts and you can order new ones from rockauto.com
Old 12-16-2013, 04:48 PM
danr1's Avatar
danr1
danr1 is offline
This thread is about five years old, gotta believe the replacement towers have been on long enough started to rust!
Old 12-16-2013, 04:55 PM
dieselpower4x4
Thanks.
you can buy them mounts for less than 50 a side on rockauto as long as you truck is single shock.
Old 12-16-2013, 05:00 PM
broncoderek's Avatar
broncoderek
broncoderek is offline
If your truck is single shock and you buy a double shock tower, can you just buy two additional shocks without buying anything else (are two lower mounts already there from the factory?
It's 15 degrees and snowy here or else I'd go out with a flashlight and check myself!
Old 12-16-2013, 10:13 PM
aj197816134
You can use the double with a single last I knew you could only get the doubles from ford! No need to add shocks
Quick Reply: Rusted Front Coil Spring Towers
