i think i blew my computer!!!!!
i was trying to do the cruise control mod. connected the harness under the dash no problem. Put a jumped wire in the connector over the brake booster and something in the the truck popped or clicked sounded like a loud relay. now I have no mileage, speedo, inside lights, keyless entry isn ' t working But the truck runs and drives But it slams gears now if your to har on it and the od light is flashing. I was told it could be the cluster others tell me its the computer. Please if anybody has had this happen to them or knows anything about this please help its my only truck and I really need it. I ' m really ready to panic if they predict snow.
ya i made it abot two blocks and knew there was a problem with the tranny shifting its a brand new rebuild i don ' t thing it did any damage driving two blocks and came straight home! I checked all the fuses that I knew about under the hood and at the dash panel believe me thats the first thing I checked
I checked every fuse in side I see the they say speedo under like 3 or 4 spots but none of them are blown and under the hood all of them are good it happened as soon as i connected the jumper wire under the hood for the cruise mod.
P.s. sorry to hear about your parents rig man that sucks I you need anything I ' m here But in mass though! It looked great too! I was following your pics you kept putting up. i will try the truck in the a.m. just trying to get all the info on this before tomorow morning its een like a new truck after the 10K, fpr shim, oil change lol! then this happens because I pissed her off I guess. Shes a great truck though Well I ' m praying for your parents on finding a truck and making it safely!
your computer can't be fried if your truck starts and runs fine although the tranny is shifting wierd. the injectors and stuff are running meaning the computer is sending the signals it needs to for all that stuff. check for power on the wires you tapped into cause if you let the magic smoke out of the wires then you need to replace the wires. that is if the fuses check out. sometimes it can be tough to tell a bad fuse but absolutely make sure none are blown.
yep got her fixed today you guys were right it was a fuse #8 interior to be exact which runs the speedo and interior lights but if you just looks at the fuse without pulling it or useing a test light on bothsides you would have never seem it it melted at the terminal instead of the middle where they are suppose to blow. it was also a melted wire at the speedo head itself and while i had the speedo head out i took it apart and cleaned it out. It looks brand new now and works good now too! Thanks for all your help!
Kris
Kris
