3.55 front with 3.50 rear?
Soft ground or not, you will be spinning your front tires or dragging your rear tires the whole time you had 4wd engaged. Even though the ring is a very small difference in ratio I would have to think that kind of stress on the transfer case can't be good for it and would drastically shorten it's life.
Just my .02
Just my .02
i have been running it in my 86 sence i have been drivein it aint had an issue yet even on pavement i havent felt a bind, the front is actually 3.54 and i think the rule is 1% so that would be .35 and with a little imagination its close enough to .4 for me so im happy with it doesnt hop in 4 wheel drive and im locked front and rear so all 4 are turnin i say go fer it.
That's what I was just going to say. You are fine with that difference. You will find the same problem with the 4.88 ratio, the 9in has 4.86. You don't want to vary too far but about 1% or less is about right, so with 3.50 ratio; plus or minus .035. Max is really 3.54 if you want to use it for the street. In some mud drag instances drivers will overdrive the front axle as much as 20% to help pull in a straight line.
Matt
Matt
Savage Eagle
23
03-29-2011 10:44 PM
Tabaker
10-13-2004 06:08 PM
