You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Anyone else have a musty smell when the a/c comes on? I took it to the dealer and they sprayed something and it kept it smelling good for about two months, now it's back. I have read spraying Lysol into the intake vents works. Any ideas?
__________________
1978 F250 Lariat 4x2
2008 Expedition Eddie Bauer 4x2
The musty smell is from the unit being run in recirculating mode too often.Spraying lysol does work but has its risks. Lysol can catch fire very quick and once the mist hits the open blower motor resistor it can cause a fire.The stuff the dealer uses is called ozium you can get it at walmart and many other places. Its the same stuff used in hospitals to control bacteria. it looks like this http://www.restockit.com/Ozium-Glycolized-Air-Sanitizer-64-oz-Vanilla-Scent--(WTB53131CWD).html?source=froogle
I used to use that stuff on my 1989 Bronco II that had recurring musty AC odor. I'd put it on RECIRC mode and blast the Ozium under the dash into the intakes. It would usually last for several months. I think it kills bacteria inside the venting that causes the odor.
Berry,
Find out if your Expy has a panel air filter, if it does, then you'd need to replace it. Mine is an older model and the panel air filter is located right under the glove compartment.
Thanks sixpak. I could not find where the a/c pulls the air from within the cab. I can hear it, I just can't see it. I am going to rig a straw onto the lysol and shoot it through the cowling. Hope it works.
__________________
airsept is approved by many mfgs and actually coats the evaporator where the mildew likes to grow. Its pretty easy to apply if you know how to get to the plenum... the applicator gun is spendy though... I did this a few years ago and haven't had any problems since...
Another interesting thing I have found is when you shut off your automatic climate control, it shuts the fresh air door. I have been doing that before I turn my car off. Since I have left it on while turning the car off, the musty smell is lessening.
__________________
This might be an answer...
A/C leaks water on passenger side floor.
It was one year and 25,000 miles of ownership before I discovered the A/C leaking water. I might not have discovered this if it was not for the see-through clear floor mats that I recently installed. Since the floor mat is see-though I had noticed water condensation on the backside of the floor mat.
2007 and 2008 Ford Expedition have a design flaw which causes the A/C evaporator coil housing box to condensate and leak water on and under the passenger side floorboard carpet. The water will run down the firewall behind and under the carpet so it may not be noticed. This is caused by a lack of insulation.
The AC evaporator coil is located on the passenger side under and glove compartment box. To test for the water leak, take a paper towel and lay it out on the left side of the passenger side floor carpet, making sure you tuck and fold some of it up over and behind the carpet between the firewall. (The firewall is the metal wall that separates the passenger compartment from the engine compartment.) Now go for a drive with your A/C on for awhile, if the temperature and humidity are just right, it will start to condensate and drip and leak water.
This can cause mold, making the inside of the vehicle smell bad and have a musty odor, and ruin the carpet and carpet padding, and overtime rust the floorboard.
To eliminate the bacteria from growing after runnning the a\c you should run the heater about 5-10 minutes before you get home or let it sit over night. this will dry out the heater box so the bacteria doesnt grow
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
