460 identifcation
460 identifcation
I went by the valve cover on mine, it also had a sticker still there that said something about 1976 emissions. I had the 1971 block and 1973 heads. D1VE and D3VE. The number just means when it was last modified, like 1971 series block was last changed in 1971, upped the deck height to 10.322 I believe. The heads were designed in 1973 and so on. The A2A or 'C' or whatever are the revision numbers, you most always want the latter letters, like 'c', because 'c' will work were 'a' once was, but not the other way. The 'V' means lincoln and 'E' is engine engineering dept.
460 identifcation
It's probably a 76.
First .....about identification.
D1VE-6015-?
This means the Block was designed in and built for starting in 1971.
There should be a Date casting code on the block between two marks like this ie: * 6C25 * Have a closer look and see what you find
The letter following the 6015-? is the change-up(design change number as mentioned)if it had been changed twice it would be 6015-C.
Same goes for the Heads,Intake Manifold,Exhaust Manifolds
They have DATE codes cast into them.
This illustration explains it.
http://www.clubfte.com/users/mil1ion/PartCastingCoding.JPG
Personally,I have never seen a casting number on a Valve cover.
Usually they just say FORD,no numbers, Just stickers.
Dennis
F.T.E. Assistant Administrator
http://www.clubfte.com/users/mil1ion/SigSanta.JPG
[font color=red]
"May The Spirit Of Christmas Be An Inspiration To You Throughout The Year"[/font]
[link:www.ford-trucks.com/guidelines.html|Club FTE]
[link: motorhaven.autoanything.com|How YOU Can Support This Site]
[link:www.clubfte.com/users/mil1ion/Mil1ion.html|My Website,"North Of The 49th"]
D1VE-6015-?
Dennis
[font color=red]
460 identifcation
Mil1ion, you said The letter following the 6015-? is the change-up(design change number as mentioned)if it had been changed twice it would be 6015-C. What does A2A mean if C is the 3rd change-up? Just curious, Thanks.
And I don't know the HP specs for a '76 460, but I bet its been posted here alot.
460 identifcation
These number you just posted tell me the Block was designed in 1971 & the heads were designed in 1973.
You need the *actual date casting codes*
On the heads it is under the valve cover in the oil galley.
On the block it is near the 6015 set of numbers.
look at the photo above for what to look for.
{b]The A2A means there were a few changes (Additions) to that part.
From something as simple to an extra tapped hole for a bracket to a hole drilled for the oiling system or a for emissions.
Here is a photo of an actual set of castings.
This is what you are looking for,usually on a machined surface.
http://www.clubfte.com/users/mil1ion/PartsCastings.JPG
Dennis
[font color=red]
Dennis
[font color=red]
460 identifcation
[updated:LAST EDITED ON 21-Dec-02 AT 02:58 PM (EST)]As Mil1ion has stated above, you have your typical casting number.
D1etc.
There is another casting date. When you see it, it looks like a plate is screwed to the mold when they cast it on that day. Mil1ion has an example of it. Flathead screw casting, then the date, flathead screw cating. I think this should be right next to the other casting number.
D1etc.
460 identifcation
Dec 10 <> 1986 or 1976 or 1966 <>
There is a thread in the I6 forum titled (Engine Year)with casting ID info on it.
A Jan
B Feb
C Mar
D Apr
E May
F June
G July
H Aug
J Sept
K Oct
L Nov
M Dec
Dennis
[font color=red]
A Jan
B Feb
C Mar
D Apr
E May
F June
G July
H Aug
J Sept
K Oct
L Nov
M Dec
Dennis
[font color=red]
460 identifcation
I just picked up my 460 rebuild project last week. Thanks to all of you who posted on this and other threads on casting codes I have come up with this.
Block # - D1VE 6015 A2B, Tells me this block was designed in 1971
Date code - 7F22, Tells me this block was cast on June 22, 1977
Question - It is my understanding that the deck height in the 460 blocks was bumped up starting with the D2VE blocks. D2VE being a '72' year designation, does my block have the lower deck height with the D1VE designation even though it was cast in '77'? I figure it does.
460 identifcation
1968-70 -- 10.300 inches
1970.5-71 -- 10.310 inches
1972+ -- 10.322 inches
Your block has the 10.310 deck height, even though it was cast in '77
I have the same block cast in '76
