Block heater
Block heater
I only drive my truck(diesel 6.0) but once a week if that in the winter and I am wondering if I should just leave the truck plugged into the block heater ALL the time? or just at night? I just didnt know whether or not leaving it plugged in all the time is a bad thing? And any other things I could do to keep it from a deep freezing. I live in Salt Lake City Utah.
The block heater will have the coolant as warm as it will get in 3-4hrs.Alot of people I know here in alberta plug the heater into a timer so it isnt drawing power the whole night. Set the timer to turn on 3 or so hours before starting the truck.As for leaving it plugged in it wont hurt anything but you may find that critters will make a home on your 6.0.
If it has been freezing all night, I like to plug into my truck's heater for two hours prior to start up. This alows the oil to warm up enough, which enables the oil to more freely coat the various internal parts of the engine at a quicker interval. This also provides easier starting with the diesel engine.
I also plug my heater into a timer that comes on about 3 to 4 hours before I plan on starting it. I did purchase an oil pan heater and tied both cords into one plug that I connect via an extension cord to the timer in my garage. Seems to work pretty good and the truck fires right up even on the coldest nights.
Just my .02 cents, and I might be a bit **** about my stuff...
Not sure if this follows the thread truly or deserves it's own, but here goes. I just bought a power cord for my block heater and read it out like the paper said to do, I am getting 15.6 OHMs but after 3-4 hours when I start my truck my temp needles barely move. Am I expecting to much from the block heater or is there something wrong?
block heaters
I have an 03 6.0 PSD, if I dont plug mine in it barely wants to run when I start it in the morning, (20deg F. in the am) when it does get going it leaks coolant at the right rear of the engine. If however I do plug it in it starts right off and doesnt leak a drop of coolant. I cant make this make sense in my mind... Any ideas?
If it doesn't want to run at +20'F something is wrong with it. I plug in @ -10'F and my truck runs great. It will start at -30F but it will run rough for a few minutes.
The coolant leak is more than likely the rubber hose on the EGR cooler, it shrinks and leaks when cold, then swells and seals when warm. There is an updated hose for this, have it changed and your leak should stop.
