wiring q's
Old 12-18-2007, 06:14 PM
dirtford79's Avatar
dirtford79
dirtford79 is offline
Arrow wiring q's
ijust need the wires to make it run & thats it id like to run it all off a couple toggle swichs thanx
Old 12-19-2007, 06:38 PM
TigerDan's Avatar
TigerDan
TigerDan is offline
Uh...it would be helpful to know what you're working on. What year, carbed or EFI? What engine? With a little more info we can steer you in the right direction.
Old 12-22-2007, 01:39 PM
dirtford79's Avatar
dirtford79
sorry its a 1991 ranger 2.3l dsi
Old 12-28-2007, 08:34 AM
TigerDan's Avatar
TigerDan
TigerDan is offline
This can be a little tough...with EFI there are lots of integrated systems, it's not as simple as hooking a up a single hot wire to the ignition on an old-style points-ignition engine. I'll have to dig out my wiring diagrams and see what I can come up with.
What are you trying to accomplish? Is this for an engine swap, or just doing away with a bad ignition switch on a farm truck or...???
Old 12-28-2007, 04:14 PM
dirtford79's Avatar
dirtford79
its for racing
Old 12-28-2007, 06:28 PM
TigerDan's Avatar
TigerDan
TigerDan is offline
Ah, that makes a difference. There are a few systems we can do away with then...but you're allowed to run EFI? Is it circle track, drag, or what...? (I used to run a mini-stock in circle track racing, but we were only allowed to run carbs, no EFI...)
I'll see what I can come up with...
Old 01-04-2008, 09:35 AM
jimdandy's Avatar
jimdandy
jimdandy is offline
For EFI you will need to retain the computer wiring harness, engine sensors, EEC and fuel pump relays. To use a toggle switch, wire it to the EEC relay from a fuse to the battery positive, and the fuel pump contact side of the relay. The EEC relay powers the fuel pump relay coil and the engine sensors and computer. jd
stealthsniper96
Electrical Systems/Wiring
04-21-2009 04:21 AM
stockernavstar
05-14-2006 10:34 AM
BOOTROS
07-01-2005 02:40 AM
96-5spd302
06-19-2004 06:12 PM
matt68
01-24-2003 01:30 PM
Quick Reply: wiring q's
