I have a04 150 with a5.4 , with 36000 miles the other day went to change oil and discovered large amount of moisture and white creamy sludge in filler neck . I think I have a head gasket problem . Getting the runaround from my Ford dealer. Anybody got any sugestions ?
Welcome to FTE! you've got the wrong forum, down one. Short trips in cold weather will cause this, nothing to be alarmed about. Just try and let it warm up more and it should cut down. Now if your oil is milky too, then you have a problem.
