Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's
how much boost
Old 12-09-2007, 03:57 PM
4ced air lightning's Avatar
4ced air lightning
4ced air lightning is offline
how much boost
im looken to get a new crank pulley for my 03 L.wondering how much more boost you can add and be safe and what programmer to get
Old 12-09-2007, 10:42 PM
Stewart_H's Avatar
Stewart_H
Stewart_H is offline
Please see this thread, post number 5.
https://www.ford-trucks.com/forums/6...yesterday.html
Stewart
Old 12-10-2007, 06:17 AM
4ced air lightning
what kind of gain with just programmer and cold air.my truck will be a driver
Old 12-10-2007, 12:08 PM
Stewart_H's Avatar
Stewart_H
Your gains would be nominal.
In my opinion, the reason for a custom tune (after a boost increase via a pulley change) is to bring the parameters of your fueling back into a safe, wide margin for daily driving, as well as to adjust the fuel and spark timing so as to take advantage of a pulley change.
Without a pulley change, all you can do is change your fuel trim, advance your spark at WOT, and adjust your shift points.
You'll basically be decreasing the trucks margin of safety for daily operation, in order to gain performance without the addition of any boost increase.
My truck is my daily driver AND my work truck. I will haul with it and pull a utility trailer without hesitation. Up to last month, I was running with a 6lb lower and a ported Eaton, with a safe custom dyno tune utilizing a handheld flash tuner.
Before I had my Eaton ported, I ran with a 4lb lower.
Stewart
Old 12-10-2007, 06:29 PM
4ced air lightning
so a 4lb pulley would be ok with a sct programmer for daily driving and would it lower gas milage alot when not on the throttle
Old 12-10-2007, 08:11 PM
Stewart_H's Avatar
Stewart_H
I wholeheartedly recommend the flash tuners because I really like them. But I don't like the "canned" tunes that are preloaded on the handhelds, and only believe in custom tunes created by a reliable tuner like Troyer (a SV here at FTE) or another reputable Lightning tuner. So I strongly suggest you contact whichever tuner you choose to create your tunes, then buy the handheld from him.
As for mileage, all I'm concerned with is Smile Per Gallon.
Stewart
Old 12-10-2007, 09:28 PM
4ced air lightning
thanks dustin
