460 build
460 build
i am soon going to be building a 460. i am going for a mild build. i am looking at the eldelbrock performer package,has anyone used this on there build? and does anybody know where i can get a link to torque specks for this build.im gonna go through this motor myself.does anybody know cheap trick to get more power from this engine,its an 86 model.thanx in advance for any input.
I would probably look at around 9:1. If you put flat tops with D0VE C heads, (or C8VE, C9) you get around 9.3:1.
Go to http://www.network54.com/Forum/85220/ for more detailed info and some ideas from some experts to get what you want out of your 385 series.
trinogt,
You said pick the right cam for your build. I am in that process now. Shooting for 550-600 horses in my mud drag f-150.Whats your thoughts on solid flat tappet cams vs hyd. flats? Aluminum edelbrocks, edel. rpm intake?, KB small dish for maybe 11:1. got to do cam lifters and pushrods anyway. already have alum. roller rockers. probably need to go to 6000rpm.
no i never took it to the track.it dynoed at 435.at 5200rpm which isnt very streeteable.i have 391 gears which ,4 barrel heads,thinking about useing the elebrock heads now available so i can make it more streetable.but first i want to get this 460 toghether and put toghether a good combo for it.
