Body Lift Question
Body Lift Question
Any of you guys with the 90-96's running a body lift with your I6? If so, what lower radiator hose did you have to change to to clear the smog pump pulley?
Jim
https://www.ford-trucks.com/dcforum/User_files/3aaa4bac6f539876.jpg
1993 F150 2WD
6" Pro-Comp Stage II Lift w/35's
Auburn Pro-Series Diff. w/4.30 gears
http://www.ProjectTrailDawg.com
Jim
1993 F150 2WD
Body Lift Question
[font size="1" color="#FF0000"]LAST EDITED ON 29-Aug-01 AT 10:14 AM (EST)[/font][p]Hey Traildawg,
I found out the hard way that the low hose didn't have enought room after the lift (belt burned a hole through the hose), so I bought 2 hoses and cut each one about an inch off center and joined them together. No problem, plenty of clearance.
GFG
95 f-150
GFG
95 f-150
PGids
01-07-2014 08:18 AM
