Super crew rear door power locks
Im not sure if this is ford design or just my truck.
I have the super crew with power locks, the doors lock automatically as they should but when it unlocks after parking the rear doors dont unlock and i need push the button to unlock the doors for the people in the rear. Is their a fix to this annoying issue
The description of the childproof locks says once the locks are unlocked, the rear doors can only be opened from the outside. The '07 autolock description doesn't describe the doors unlocking automatically. Do the fronts really unlock when you park, or is it just that pulling the inside handle unlocks and opens the door?
I find the same thing annoying on my truck, having to unlock the doors to let other people out or to get things out of the back seat. I think the front doors unlock when you use the door handles to get out. I drive a newer ford at work and it does the same thing. I hope there is a way to change it so either all the doors unlock when the car is put in park or the doors do not lock at all.
i had an 05 sc lariat, what i did was ask the dealer to see if they got an upgrade for the keyless entry system to a complete car alarm system, and it just happen that there is, and also asked about my key pad to see if it's gonna work and again it was a yes, same remote i'm using, and can be programmed to where you can unlock all doors once you pull the key out of the ignition and auto lock all doors once you turn on the ignition....
It's just the way the stupid system works.
I can only assume it is to retain people that you are transporting against their will!!! lol
On a serious note...my kids have learned to pull the lock **** up and are sometimes out before me.
To me it's more aggrivating when I am alone because if I go back to the truck to get something out of it I have to dig in my pocket for the keys cause the damn door is locked!!!
DMAC
Looking at an 04+ wiring manual, all the auto-door lock functions come out of the Body Control Module. It's located behind the left rear passenger seat back. You can make all the doors open at the same time the driver's opens, if you want to splice a wire...and you want to assume responsibility for any consequences of this mod!
There are 2 plugs that come off the BCM, C3008a (colored blue) and C3008b (colored green). On the Blue plug, pin 5 has a Red w/ Orange stripe wire...that is for the Drivers Door Unlock. Pin 3 has a Pink w/ Orange stripe wire...that is for ALL PASSENGER DOORS Unlock (reg cab, s-cab, or screw...all the same config). Simply cut the Pink w/ Orange stripe wire at least 2" from the plug (in case you want to restore it in the future) and splice to the Red w/ Orange stripe wire...and all doors will unlock at the same time.
BTW, all doors (driver's and pass) share the same Pink w/ Black stripe Lock wire.
I don't know the trick to removing the seat back in the different models, though!!
I know that my 01 focus, my aunts 06 F-150, my other aunts 03 Expedition they all do that, it is just a safety feature to make it so little kids don't fall out of the car becaue of opening the door. BTW Don I was reading your sig. and your fusion doesn't have a 4.0L V-6, it is either a 2.3L 4 cyl. or 3.0L V-6.
check out this link.
I did a quick search and found this link. It will answer all your questions
https://www.ford-trucks.com/forums/6...ck-unlock.html
Why do they have to lock in the first place? Do they think this will make us safer in a crash or is it because we are too stupid to do it ourselves?
At least with a Ford the front doors will open with the handle even when locked.
I had a Chevy and I always had to unlock it first before I could open the door. Didn't really bother me when I was alone as I never lock the thing, but me wife is one of the lock freaks and would lock the darn doors before I even got the truck started.
