how much is to much boost
#31
#33
on
Originally Posted by ForemanES
So its actually machined out? I was thinking it had an aftermarket snail shell and wheel. It would be nice if it came with a 4" intake instead of the 3".
How can you tell when the thrust bearings are toast? Does it sound like my endplay and drag while spinning situation?
To check thrust bearings remove the intake tubing. with a cold engine (so you don't burn yourself) grap the end of the shaft and push and pull inline with the shaft (actually left to right of the truck, not side to side of the turbo, forward and back on the truck), you should have no movement. the spec is .008 of an inch.
Flea if you have a cali truck you will have a UFO disc on the rear of the fuel pump.
#34
#35
#37
#38
on
oh ok, so what does the side to side movement mean? (front to back of truck). There is my 1/32-1/16" play
I just checked the thrust bearing and there is no noticeable play.
#40
on
Originally Posted by Dave Sponaugle
Stock Power Strokes only run 10 or 12 PSI boost?
No wonder I have so much fun with my 6.9 at 25 PSI.
#41
#42
#43
Originally Posted by tjbeggs
Some run that low but thats not the norm. 15 is what I consider norm but usually 16-17 also. My 95 ran 20 stock. My 97 in current form sees 33 even after the intercooler install just takes a little longer to get there than before the IC.
#44
Being pretty new to modding these trucks, I'd be curious to know what I've added at the flywheel and wheels.
I have nothing but seat of the pants to go by.
What would some of you more experienced guys think Im pushing?
95 with 280k on it. So the stock 225 was probably 175...lol
I've added so far
60hp super chip
4" dp
4" straight all the way back
Stage 1 DIY's
The wix air filter swap listed here
A TPS built auto, with a TCi converter
I dont what power it made, but I was pleased that my buddy couldnt pull away on me in his 08 duramax. Mind you, the duramx is stock of course.....lol
Definately feels like I've put 100plus hp to the wheels, but I dont really know.
I have a 99 intercooler to go in, and am looking at a DP tuner chip, and snow performance stage 2 in the new year.
Im shooting for big towable power. I need to haul somewhere in the range of 12-13000lbs on our road trips.
Will the dp, intercooler, and meth make a significant difference over what Im running now? I mean, Im sure it will, but wondering how dramatic it will be.
I've added so far
60hp super chip
4" dp
Stage 1 DIY's
#45
I've added so far
60hp super chip
4" dp
Stage 1 DIY's
I've added so far
60hp super chip
4" dp
Stage 1 DIY's
as for the reason he didn't just plain run from you... maybe he's heavier?? gearing... speed you started out at (gearing is involved in this).... too many variables to list....
the dp will make a HUGE difference... especially in EGT drop... i hope you have gauges, if not that should be the next thing you do, the intercooler won't make too much of a difference if you're not puffing smoke like crazy once the trubo spools.... the meth will lower EGTs but i would look at new turbo like the d66 or h2e instead of a water-meth kid...
just my 2cents
rcogs
10-17-2009 06:42 PM
