I have a 97 powerstroke and the fuelpump is leaking so Im replacing it but how do you get the bolt out of the back with out taking the turbo off is there a tool for this or does someone know the size so i can make a tool to get to it.
Hey 1tons4life,
The 1 without the starship is non-cali, and the banjo fitting bolts directly to the front of the pump. and is quite accessible.
Hope this helped a little.
Can anyone tell me about the tappet? I read that it is possible that it could fall into the engine while removing the pump and that you should bump the engine over till the cam lobe is at the top. I have never seen a pump or tappet in person, so I don't have a concrete idea of the danger.
Is the tappet attached to the pump by friction only?
Would it be possible to run a string under the pump after the bolts are removed and tie it off before removing the pump?
