Why are BFG A/T load range E not severe snow rated if the D rated tires are?
I have heard great things about the BFGoodrich A/Ts from people in similar climates, but I believe most of them have gone with the D rated tires (most of the people I know of only drive 1/4 ton) which are severe snow rated...I cant figure out why the E load ratings wouldnt be rated for severe snow as well? The tread pattern is the same, and the rubber composition shouldnt be too different.
Any ideas on why the difference in snow ratings for load range D vs E?? I will be putting them on my 03 250 SD V8 fx4. I dont haul much other than maybe 300 - 800 pounds of timber at the very most a few times a year and only tow maybe once every 2 years. The truck is my daily driver and I probably didnt need the 250...but err...it looked cooler than the 150 lol. So anyway I could get away with D rated, but I would prefer to go E if there is no draw backs.
Originally Posted by jlstorm
...Any ideas on why the difference in snow ratings for load range D vs E?? I will be putting them on my 03 250 SD V8 fx4. I dont haul much other than maybe 300 - 800 pounds of timber at the very most a few times a year and only tow maybe once every 2 years. The truck is my daily driver and I probably didnt need the 250...but err...it looked cooler than the 150 lol. So anyway I could get away with D rated, but I would prefer to go E if there is no draw backs.
He's right, guys. Some of these trucks came stock with 265/75-16s, and that particular size is not rated for "severe snow" in the E load rated tires by BFG. Same for the MTs. Other available sizes are.
I don't have the specific answer to your question, but my guess is that for some reason that particular tire is made with a harder compund and/or has less sidewall flex, which will affect your mud/snow traction.
I just bought the D tires for my truck, as I was more worried about traction than load rating. On my truck, the load rating on the D tires perfectly matched the load rating on my axles anyway. I only tow/haul occasionally and probably never overload the truck. I also monitor tire pressures pretty religously. I think if you follow those habits, you should have no problem.
Originally Posted by swann79
huh? Read the OP!
Originally Posted by Ace!
I did. He thinks load range "E" tires are not severe snow rated. At least that's the way I read it. The load rating isn't what gives them the snow rating, so he's wrong. There are numerous load range E BFG ATs that have the rating, aren't there?
