If I have a aftermarket 75mm throttle body on my 2003 f150 king ranch 5.4L V8 will a stock airraid throttle body spacer fit and does anyone know if it helps any?
hot rod magazine gained 1 hp and 5lb tq on a pontiac 400 that they where building up... that was after upgrading many other things.... i dont know if it works the same for fuel injected engines as carb'd engines..
No it will work better in a carbed engine because it will mix the fuel and air better in the carb, but on a Fuel Injected motor it usually doesnt benefit.
I dont think it has much to do with the actual mixing... but more to do with the volume of air in the intake....but since the 4.6l has a variable volume intake...it dosnt make much sense...but the 5.4l doesnt have the variable volume intake....maybe it will help more on it....
