Has anyone disconnect'd A/C during winter season???.....
.......just as title state's, was wondering if doing this during just the winter month's would hurt anything???? . . . . . . .[ Basically, thinking of just disconnecting the Compressor ] . . . . . . I mean gzzzz, this 5.8L eng would REAAAAALLLLYYY save & get better on gas mileage and all without the compressor kicking on and off =IF= using just the heater now and then .....IF this tend's to work out descent & without any problem's of, then i just might decide to put in a switch hidden under the dash to do just this for just the seasonal purpose of...........Please chime in and give comment's / suggestion's / or whatever your thought's OR know of a BAD_prob of doing such, thx...... ....
mr. Charles
mr. Charles
I know on newer cars, when you have defrost on the A/C kicks in. Something to do with mixin the hot and cold air to keep windsheild from refoging or something like that. I forget the exact. As i dont have A/C in my tuck I wouldnt know if yours is supposed to. Maybe someone with same year and a/c will know.
Originally Posted by 17fordguy
well i thought if the ac was off the compressor wouldnt kick on
mr. Charles
Lets see a 10 ish year old truck . It works now why unhook unless its completely . It will be sitting for x amount of months things will be effected. Like moisture build up . Bearings Etc. Compressors are not cheap
I removed (broken bracket and condenser) compressor after a run in with a deer on one truck .My MPG improve not at all . I keep records and was not more the couple tenths and thats over 6 month period.And notice no performance improvement .
Keep it hooked up or not its up to you .
You're in the PNW/WA right? You'll need the A/C to dehumidify the interior in the wet weather/winter... I use it all the time in the Minnesota winters because of all the snow that will melt off your shoes/clothes and fog up the windows...
Very little is saved, and more to be lost not using it for months at a time...
Like posted before It'll come on when you're using the DEF or DEF-HEAT(Bi-Level) positions.
........just wanted to say "THANK's" for all your comment's /suggestion's / & Very good point's made for the "pro's" of just leaving this connected and all.... .....guess i'll just leave this as IS and then digg deeper into the pocket's here for the price of GAS gettin up into the 3.30 to 3.50 range for Reg, for now; and wouldn't put it pass that it WILL hit the $4.00 mark by xmas/new year's........gzzzzzzzz !!!!
. . . . . .again, thx-2-u-all who gave a bit-of-time for here. . .
mr. Charles
mr. Charles
