hi im mike,a new member and i need help,i have 88 ranger 4x4 and it has the push botton four wheel drive .it will not work i got power to every thing,is it the t-case motor? its the borg-warner 13-50 t-case can any one help.thanks
Welcome to FTE Mike!! While I don't know much about the Rangers, I'm sure someone will chime in for you soon!! You may get a quicker response if you post this in the main forum. The WAFTE boards get kinda quiet at times. Good Luck!!
Sorry, mine has levers and manual locking hubs. Of course, mine is a 1972 F250 Ranger. I have never dealt with the push button system of the little Rangers.
thanks to all thanks, i found out that it is my t-case motor.if any one that has the push button 4x4,rangers,B11s and explores if it stops working it is 99% the t-case motor ,if u dont use it alot it mite go, so when ever u get achance ingage it and go acouple of miles.do not do this on pavement, most likely to bind.i got my info from jamesduff.com they dill with rangers,broncos and B11s only. they have tons of stuff to make your rig off-road werthy.they are in the middle of changing there web site so they dont have every thing up but some. any wayz thanks 2 all that tryed to help.mkpecor p.s they are electronic.
