6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Upfitter switch for High idle
Old 06-13-2009, 11:26 PM
John7894's Avatar
John7894
John7894 is offline
Gotcha. Is there any way to change the current rating of the switches? Is there a fuse anywhere, or a relay that can be changed? I've only had the truck for 2 weeks so I haven't crawled around it that much yet. I plan to do that tomorrow.
  #62
Old 06-14-2009, 12:24 AM
Super08's Avatar
Super08
Super08 is offline
I believe the relays are in a block and the assignments cannot be changed. I could be wrong as it has been awhile since I looked at anything having to do with them. See if anyone else chimes in.
  #63
Old 06-14-2009, 08:04 AM
alchymist's Avatar
alchymist
alchymist is offline
"Mifflin Clay"
The switch ratings are according to the wire size in the harness. I think the ratings change also. If I remember correctly it was something like two 30 amp and two 10 amp originally, and changed to two 30s, a 10 and a 15. Don't have my manuals on disk here, someone correct me if wrong...?
  #64
Old 06-14-2009, 08:14 AM
Super08's Avatar
Super08
Super08 is offline
Also he mentioned the use of switch #3. I have always used switch #4 when I hook up a high idle. I didn`t catch that at first.
  #65
Old 02-10-2010, 09:36 PM
Boat Hauler's Avatar
Boat Hauler
Boat Hauler is offline
Another stupid question! I asked my dealer to do this for me a couple of weeks ago when I was in for an oil change and they looked at me like I was completely crazy. How could it be possible that they won't do this for a customer?
  #66
Old 09-13-2010, 12:38 PM
kat_man_2's Avatar
kat_man_2
kat_man_2 is offline
Just picked up a 2008 F250, low miles, cherry condition. A question on the high idle mod: Is there a way to bypass the requirement for the e-brake to be engaged? I live in a sub arctic zone, and if you apply an e-brake up here, it's not coming off again 'till April. I'd really like to do this to shorten up those January morning warmup times.
  #67
Old 09-13-2010, 04:43 PM
71stang99's Avatar
71stang99
71stang99 is offline
Temporarily Deactivated
Just finished mine, took all of 15 minutes max. The hardest part for me was the initial location of the upfitter wires, pretty much on my truck they were directly above the bundle for the PTO wire. There was enough length to connect the two without a splice wire and I connected them together with a wire nut. (yellow/green wire and the #4 upfitter switch which is brown)
I did remove the trim piece under the steering wheel but both of the wire bundles were to the left of a silver box and were unaccessible with that trim piece removed. I had to go under the dash so to speak to get to the wire bundles.
Works as advertised when the parking brake is set its idles up to 1200 and will return to normal when the brake pedal is tapped, emergency brake is released or turning off the upfitter switch.
Super easy mod.
  #68
Old 09-13-2010, 06:17 PM
koboss1's Avatar
koboss1
koboss1 is offline
i tried this the other day and had nothing i connected the yellow with green tracer to the brown wire put on the parking brake and turned on the #4 switch and got nothing?? please help
koboss
  #69
Old 09-13-2010, 10:45 PM
71stang99's Avatar
71stang99
i dont know what the problem might be, if the parking brake is set, I turn the truck on and flick on the upfitter switch and it works. seems to work with the engine on and putting the PB on and then flipping up the upfitter switch so its working for me????
  #70
Old 09-18-2010, 11:29 AM
kat_man_2's Avatar
kat_man_2
Anyone...? Anyone...? Bueller?... Anyone...?
  #71
Old 09-18-2010, 03:02 PM
John7894's Avatar
John7894
John7894 is offline
koboss
I'd make sure the switch will ouput power. If memory serves me correct there are some relays with the switches too. Maybe the relay is bad, or not there?
  #72
Old 09-18-2010, 03:36 PM
koboss1's Avatar
koboss1
koboss1 is offline
its wierd cause when i put the test light on it, it didnt light up with the switch on but the light in the switch lights up
  #73
Old 09-18-2010, 09:24 PM
John7894's Avatar
John7894
John7894 is offline
Do you know if there is supposed to be a relay in there? I thought I remembered the switch energized a relay and the relay output hooked to the load. If this is how it's supposed to be then it sound slike the relay is missing or bad. The switch would use the source power to energize the relay and light the small light on the switch.
  #74
Old 09-18-2010, 10:13 PM
Super08's Avatar
Super08
Super08 is offline
You would have to find out what signal the computer it looking for. I would guess it is a limit switch down by the park brake pedal that sends the signal. If so just wire in a toggle switch to close the circuit and you should be good to go. It wouldn't take much to do a test to see if it will work.
  #75
Old 10-24-2010, 09:06 PM
clane's Avatar
clane
clane is offline
I have a 2010 with no uplifter switches. Is there another wire that is hot with the key that I can hook to? I found the yellow and green PTO switch but can't find a hot brown wire.
Quick Reply: Upfitter switch for High idle
