2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Stereo wiring diagram help
Old 11-07-2007, 07:24 PM
nfntruth's Avatar
nfntruth
nfntruth is offline
I tried to thread jack in another posting, but it didn't work. I am trying to install a high level to low level (speaker wire to RCA) converter so I can hook up my bass shakers in my seats but I need the color breakdown on the back of the head unit so I can splice into it correctly. If someone has the maintenance DVD and can post the colors up, it would be much appreciated. I have the 6disc MP3 changer with sirius radio, no sub woofer. I pull back in to port in a few days and would like to do it then.
FYI, the stereo is VERY easy to access. That trim around the control area is just a snap in piece. Get a panel puller, it pops right out, or you can use a screw driver but be careful to not scratch the plastic. There is enough slack on all the cables that you do not have to disconnect anything. Then its just 4 bolts holding the radio in. Piece of cake. Should take the average person less than 5 minutes to do. There is tons of space in there as well for those who want to add an aftermarket setup with say a blue tooth adapter, HD radio receiver and so on...
Old 11-08-2007, 12:45 PM
berry1234's Avatar
berry1234
berry1234 is offline
From the service dvd
LF
WH +
WH-BN -
RF
WH-VT +
WH-OR -
LR
BN-GN +
BN-YE -
RR
BN-WH +
BN-BU -
What is a panel puller? I would like to take a peak back there too.
Old 11-08-2007, 04:45 PM
IQ9's Avatar
IQ9
IQ9 is offline
Panel pullers can be bought at local auto parts store for 5-10 bucks. They are sometimes found in the rack of "HELP" stuff. Usually a shaped piece of metal with the correct shape for popping the plastic push nuts off. The better one have nice handles-I have cheap and expensive both work well.
Old 11-08-2007, 04:55 PM
berry1234's Avatar
berry1234
This looks like it would work without marring the gray plastic.
Old 11-08-2007, 07:09 PM
nfntruth's Avatar
nfntruth
nfntruth is offline
My panel puller is a bit different, but was found in the help isle. It does everything, headlight adjustment, door **** clips, windshield clips and so on. It was 7.99 I think. But thanks for the wiring breakdown, I will post some pics when I open it up tomorrow after get home, a very very short how to.
Old 11-08-2007, 07:13 PM
berry1234's Avatar
berry1234
Cool. .
Old 11-08-2007, 09:23 PM
IQ9's Avatar
IQ9
IQ9 is offline
Looking forward to the "how to".
Old 11-12-2007, 08:15 PM
nfntruth's Avatar
nfntruth
nfntruth is offline
Thanks, it was almost exactly right, the front left was a bit different, but they were smart enough to electrical tape together the associated pairs, so it wasn't too bad. Thanks again for the starting point.
Old 12-02-2007, 02:01 AM
chester75's Avatar
chester75
chester75 is offline
DOES ANYONE HAVE THE WIRING SCHEMATIC FOR OVERHEAD DVD IN A 07 EXPEDITION.BOUGHT ONE OFF EBAY.GOING TO PUT IN 06 CREW F250.ALL HELP WOULD BE APRECIATED. shwn_jackson@yahoo.com
KhanTyranitar
Aerostar
54
05-31-2020 11:33 AM
creator
1999 to 2016 Super Duty
04-13-2012 09:26 AM
kenworthfan
1983 - 2012 Ranger & B-Series
03-01-2011 03:59 AM
kontoboy
09-12-2010 10:58 PM
Quick Reply: Stereo wiring diagram help
