Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Explorer, Sport Trac, Mountaineer & Aviator
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 11-07-2007, 07:41 PM
emf1367 is starting off with a positive reputation.
Angry $102 for a cruise control light bulb!
The light on the left side crusie control button (on/off) stopped working. I took apart the switch and see there is a small blue bulb located in a socket on the circuit board. I called the local Ford dealership and was told I hadd to buy a new switch assembly because they don't sell the bulb seperately. The switch is $102.00 and some change.
Seems ridiculous that the circuit board has a removable socket but Ford wont sell the bulb.
Has anyone tried to replace the bulb using an aftermarket electronics supplier? Does anyone know the wattage and/or voltage of the bulb? Ilike to have everything in the truck operational but I won't ever be able to justify a one hundred dollar light bulb.
Thanks in advance for your assistance.
Eric
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 11-07-2007, 09:14 PM
97 Mountain Man is starting off with a positive reputation.
I think you can get bulbs from Radio Shack. You might have to solder it in though.
__________________
1997 Mountaineer 5.0 2" lift
15x8 Dick Cepep DC1-Black with 31x10.5x15 Timberline AT II"s
Rancho RSX
  #3 (permalink)
Old 11-07-2007, 09:38 PM
CobraXP's Avatar
CobraXP is a splendid one to beholdCobraXP is a splendid one to beholdCobraXP is a splendid one to beholdCobraXP is a splendid one to beholdCobraXP is a splendid one to beholdCobraXP is a splendid one to beholdCobraXP is a splendid one to behold
They sell the bulb separately. Here is a pic of the bulb numbers for different things:
(Have to give credit for the pic to someone else. Got it YEARS ago... )
__________________
David
FTE Super Moderator
Join us in the Utah Chapter!!!
When you can't buy what you want, build what you want.
  #4 (permalink)
Old 11-07-2007, 09:40 PM
bcjim is starting off with a positive reputation.
Id be careful, you want that system working when you need it....and not going off unexpectedly. I replaced my switch 3-4 years ago, if I have to do it again, I can live with replacing 2 $100 switches over a 12-14 year period, I really doubt I'll own it longer than that..
Edit. Misssed Cobra's post- In that case, I'd buy the bulb.
__________________
98 Ranger SC 4X4
03 Explorer 4x4
  #5 (permalink)
Old 11-08-2007, 09:16 AM
RedBoat's Avatar
RedBoat is starting off with a positive reputation.
also look on flea-bay I just bought a new set of both buttons. They are new ford oem switches for $30 and that included shipping. I wish I hadnt thrown my old set away the bulb was good just the plastic button material broke I could have sent you the bulb for nothin.
__________________
Costa
2003, F-250, 7.3L, 2wd, Auto, 4 Door, Lariat, Short Box
DP-Tuner, Isspro Pyro, Boost, and Tranny Temp, 6637
with Petes cover, Fumoto, Bilsteins, Michelin LT285/75R/16 LTX AT2's
2005 Explorer XLS
2007 Chevy Tahoe LT2
  #6 (permalink)
Old 11-08-2007, 10:36 AM
fraxinusalba is starting off with a positive reputation.
I have replaced the bulbs in several switches and buttons with bulbs from Radio Shack. The Radio Shack bulb is slightly larger in diameter than the original and won't fit all the way into the plastic piece but will work. Your bulb isn't actually blue - it has a blue plastic cap over the end. That plastic cap won't fit over the Radio Shack bulb so I coat it with blue fingernail polish. The bulbs are 12 volt. You don't have to solder them in. Last time I bought the Radio Shack bulbs, they were about $1.
Last time I checked dealer for bulbs CobraXP gives above, they were no longer available. Had to buy entire switch. Maybe you can find them on internet somewhere though.
  #7 (permalink)
Old 11-10-2007, 02:18 PM
drifter is starting off with a positive reputation.
Check on www.directfordparts.com They list the foglight bulb for $3.45; the headlight bulb for $5.31; the CC bulb for $ 3.82. Not sure if they're still available, just posting what the site lists. Hope this helps.
  #8 (permalink)
Old 11-11-2007, 04:46 AM
ukexplorer is starting off with a positive reputation.
You can get wire ended bulbs in 3 mm and 5 mm diameter from electronic suppliers. You can carefully remove the old bulb from the holder, push the new bulb through and wrap the wires round the grooves at the end. Re-use the coloured cover and you have a cheap replacement. Try it!
  #9 (permalink)
Old 11-13-2007, 11:04 AM
Tennesseepowerstroke is starting off with a positive reputation.
Any advice on how to remove or pop the switch off to get to the bulb. I have a Haynes manual that doesn't mention this and I don't want to take a chance and break the switch.
Thanks
__________________
03 F350 6.0 DRW CC 4x4 Lariet White/Arizona Beige FX4 Moonroof 6 CD 4.10 L/S 39,000 miles
97 Mountaineer 302V8 AWD Toredor Red/Charcoal Moonroof JBL 3.73 L/S 159,000 miles
06 Milan V6 Vivid Red Moonroof leather 10,000 miles
Updated 2-17-08
  #10 (permalink)
Old 11-15-2007, 12:32 AM
I changed to LED's after reading the information at http://www.cardomain.com/ride/296394/23 This guy does a great job explaining the process so just about anyone with a soldering iron could make the switch. I used blue LED's and they look really cool.
I spent $10.00 for the LED's and $0.99 for the resistors. It was an easy transformation. If you try it make sure you diffuse the LED's, otherwise certain areas on the switch will be brighter than other areas.
Thanks to each of you for your information and advice.
Eric
  #11 (permalink)
Old 11-15-2007, 07:40 AM
Thanks for the link Eric.
Greg
__________________
Updated 2-17-08
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
