bad ignition module symptoms?
Old 11-07-2007, 02:43 PM
fordinmudd's Avatar
fordinmudd
fordinmudd is offline
do ignition modules act up and have symptoms when there starting to go bad?or do they just die and thats it?
Old 11-07-2007, 04:42 PM
Franklin2's Avatar
Franklin2
Franklin2 is offline
Received 1,713 Likes on 1,385 Posts
The most common partial failure is heat related. You will be driving along and it will quit. After it cools off, will run again till it warms up and quits again. Otherwise, it usually is dead and won't do anything at anytime.
Old 11-07-2007, 08:40 PM
blue beast's Avatar
blue beast
blue beast is offline
Carrying a can of keyboard duster and holding it upside down and blasting the module
will get you off the side of the road quicker if it fails due to heat failure!! Just try 20
seconds or so to start and see if it cranks back up. It also works for coils and other
electrical components and even fuel line heat(vapor lock) problems. So keep a half
empty can in your truck and wait 7 minutes instead of waiting an hour for it to cool!!
I super glued a heatsink to the back of mine and ran a intake tube to the distributor
area to get a blast of cold air from the radiator support blowing on to it.
Old 11-13-2007, 04:13 PM
PerfDistIgnition's Avatar
PerfDistIgnition
PerfDistIgnition is online now
FTE Sponsor
Sometimes they can cause your timing mark to jump around very erratically, 6 to 10 degrees.
http://www.PerformanceDistributors.com
__________________
FTE Sponsor
Performance Distributors
MustangGT221
28
08-14-2016 09:22 AM
Glenn.b1
13
05-09-2015 02:05 PM
Superdave
42
11-21-2010 02:00 PM
jmc0369
10-01-2010 06:56 AM
FordLuvinJarhead
Electrical Systems/Wiring
07-01-2003 09:45 AM
Quick Reply: bad ignition module symptoms?
