broken exhaust studs 5.4
Hi all i was wondering about the procedure for the two rear studs broken on my 02 king ranch. should i just cut the nuts off the other studs, and try to remove the other studs with a stud removal tool. or??? thanks for any suggestions. Neil my email is nmattison@aol.com
i would definitely try backing out the other studs with the nuts, 9 times out of 10 the nuts are rusted to the studs but the studs back out of the head fairly easily. Replace the gaskets with fel-pro, not the ford gaskets as these are the same stainless shims that are leaking on your truck now. The fel-pros are thicker and more pliable. More than likely your studs broke because your manifold is warped. If you put a straightedge on it, you'll see it's probably off by more than 1/16". Make sure you replace your studs and nuts (all of them!) with ford parts as KR said, and use anti-seize on both ends. I did this about a month ago, but they're already leaking so i'm just going with headers as they're about half the price of oem manifolds.
thanks for the info guys. hey John my truck is a super crew,and its brown. we love it. im actually my 53 f100 will have a set of buckets out of a king ranch with a 351w. my engine builder said its going to be a wicked stump puller. he said its going to have a ll kinds of ft lbs of torque. i cant wait. thanks again Neil
rswart
05-10-2004 07:37 PM
