Modular V10 (6.8l)
Now HERE is how you fix a blown plug!
Old 11-02-2007, 11:37 AM
krewat's Avatar
krewat
krewat is offline
Site Administrator
http://cgi.ebay.com/ebaymotors/ws/eB...RL:MOTORS:1123
At least you won't hear the Whoot-ik-a
Old 11-02-2007, 12:06 PM
dkf's Avatar
dkf
dkf is offline
I guess that guy has never heard of a tow truck.
If my truck blew a plug no way I'd drive it anywhere.
Old 11-02-2007, 01:34 PM
krewat's Avatar
krewat
krewat is offline
Site Administrator
Actually, it won't hurt anything driving it like that.
The only thing you have to do is disconnect the fuel injector. Even though Ford's OBD-II implementation should shut off the injector when it detects a misfiring cylinder, I'm not entirely sure the pre-2002 ones will...
https://www.ford-trucks.com/forums/5...t-come-on.html
Old 11-02-2007, 02:58 PM
hydro_37's Avatar
hydro_37
hydro_37 is offline
Looks like a neat idea. My luck the plug would blow out in the middle of the night, no flashlight or tools, so I wouldn't be able to use it anyway...lol
Old 11-02-2007, 05:10 PM
boxcar1974's Avatar
boxcar1974
boxcar1974 is offline
And as the plug erupts it will take out the fuel rail with it and have gas leak down on the exhaust manifold and catch fire.
Old 11-02-2007, 06:15 PM
Monsta's Avatar
Monsta
Monsta is offline
Sit. Stay.
Maybe they should makes sparkplugs out of those "plugs".
Old 11-02-2007, 07:54 PM
commandtoad2's Avatar
commandtoad2
commandtoad2 is offline
mine blew out while towing my jeep from tellico about 120mi from the house.
pulled the FI plug and kept going. although the fuel mi went to hell, i still kept up with the convoy going 80mph !
Old 11-02-2007, 10:08 PM
krewat's Avatar
krewat
krewat is offline
Site Administrator
As far as I know, that's only happened to ONE F150. And that's questionable, being it's on that lawyer's "consumer protection" website.
Old 11-03-2007, 01:57 PM
gojoe's Avatar
gojoe
gojoe is offline
I see 5 or 6 plugs a year blow out and I've lost one in each of my current vehicles. I've only seen one factory plug exit a head (cop car, go figure). None I've ever seen have gotten out of the coil boot or caused any damage past the coil.
Many can be fixed with a GOOD repair kit,(thats how I fixed my Excursion) but most kits don't use a good enough insert to hold properly and are therefore considered temporary repairs. My '01 F250 is currently awaiting parts for this repair because the hole was to damaged to accept an insert (due to poor quality helicoil installed previous to my ownership).
My experience says it's not a Ford issue but the fact that aluminum requires different handling than cast iron heads as evidenced that almost every case I've seen has had aftermarket plugs in them, meaning they weren't changed by a Ford dealer or technician. I can't even guess how many plugs I've changed at 100k intervals and never had one come out, yet both of my current vehicles (bought used with low mileages, 53k and 69k, had plugs replaced which blew out). The engine should be cool, the plugs should be torqued properly and I highly recommend Motorcraft plugs.
By the way when I lost the plug on my Excursion I simply unplugged the coil and injector and drove 75 miles home at 60+ no problem, except fuel mileage, but I only get 9-10 anyway so how bad is 7 really? LOL
Old 11-03-2007, 02:14 PM
MadMedic20's Avatar
MadMedic20
MadMedic20 is offline
I wonder how many people are going to use that and have piston to plug contact?
Old 11-05-2007, 04:14 AM
1's Avatar
1 is offline
That has got to be one of the worst idea's i have ever seen. Just wow.
Old 11-05-2007, 09:02 AM
krewat's Avatar
krewat
krewat is offline
Site Administrator
It's only a band-aid to plug the hole - it's not meant to allow a spark plug to stay in there...
Old 11-05-2007, 11:51 AM
MadMedic20's Avatar
MadMedic20
Its just a rubber expansion plug. There is no collar or anything to keep you from putting it in to far. Someone is going to gouge a piston.
Old 11-05-2007, 11:59 AM
Big Orn's Avatar
Big Orn
Big Orn is offline
Here's what I liked about it:
The only tools needed for installation would be a standard 1/2" wrench...
A 1/2" wrench? Gee...whooda thunk I could use that? Open or boxed end, ya reckon?
Old 11-05-2007, 01:35 PM
krewat's Avatar
krewat
krewat is offline
Site Administrator
I don't know why you'd think that - the plug is about the diameter of the recess in the head, the entire rubber plug isn't going to go through the threaded "plug hole".
Quick Reply: Now HERE is how you fix a blown plug!
