1957 F100 Pitman arm
Hi
I am looking for a 57 F100 pitman arm. I have been told that this is a one year only item and that in 58 and up the sector hole dia is larger. My sector shaft
hole appears to be 1 1/4"
Can anyone cast any light on this ?
Or better still does someone have one to sell
Thanks
Thanks
Originally Posted by mrcman58
I just had a look at the 57 manual for a Part number, its showing 1/2 ton and also 3/4 ton used the same part, the part # is B7C 3590 A... i will still PM you after i check to see if i have it. Jess
The number was later updated in the 1957/63 Ford Truck Parts Catalog to: B8C-3590-A.
Ford cast an engineering ID number on most of their Pitman Arms.
The ID casting number found on the arm for either B7C-3590-A or B8C-3590-A is: TAAK-3590-B
The actual Ford part number will not be found on Ford parts after circa 1953. Only engineering/casting numbers were used after that date.
Bessie
02-16-2016 12:13 AM
dlb.motorman
02-04-2015 08:48 AM
olguy317
17
09-11-2014 03:40 PM
