Fabtech Coil Over Conversion
Originally Posted by V10raisinCane
You can also look into SkyKing Coilovers. They make about every size you can think of, and if you, or any one you know has any fabricating skills, you can easliy make, or even buy the control arms, and set everything up. That is the way I would do it. Offroad makes a huge difference between coils and leaf springs, ride quality, flex, everything just gets a little better.
I made a mistake, Skyking is made by skyjacker, its just King Coils. Check them out on ebay, you will be able to find them on there. I tried to find the website but I was unable to do so. I'm at my office and our restrictions are retarded, I guess it was considered entertainment by the restriction thing, not really sure what that thing would call this website, but oh well.
http://www.skyjacker.com/products/pr...detail/?id=661
They also make a 8" kit but no 4" kits.
Just a thought, has anyone access to Ford part numbers that they could come up with a complete parts list of OE '05+ F-250/350 suspension components to make a complete setup to mirror how the '05+ trucks are setup?
One problem I can think of is the '05's are using Dana 60's where the Excursion and F-250/350 pre '05 are using Dana 50's. The bracket that is welded (maybe it is bolted) to the axle where the radius arm / control arm bolts up to, could that bracket be bought seperatley and installed on a Dana 50?
Unfortunately I live in Yuppie Suburbia Ville w/ HOA Covenants. I don't have the space (or the place to hide) such a parts vehicle right now (Oh how I yearn for the old days). I need kits or parts I can just add to the ride. My problem - Not any of your worries!
If anyone has access or knows where I could purchase the Ford Parts Master CD for an '05 - '07 F250/350 I would greatly appreciate it. I think I am going to try to acquire parts and go that route. - Thanks!
On the Fabtech 6" Coilover kit; does anyone know or take a good guess - that if custom coil were made lowering the vehicle height another 2" to essentially make a 4" lift. How far would that push the axle forward and possibly bind up the spring in relation to where the spring perches/buckets mount to the frame?
The only way on I know how is to try it, I have made some models and drawings and don't see it being a huge issue. But I do know on the '05 Superduty lift kits that they are making a taller bracket (where the radius arm mounts/pivots to the frame), dropping the radius are down in relation to the spring height. Am I making any sense?
However, I would be more concerned with your ability to adjust the castor of the front axle (too much castor with the shorter spring on a longer control arm) and how that might afect either your steering and or your front driveline bind, vibration, or length. Are these control arms not adjustable? If so, they should easily be able to adjust enough for the shorter coilovers.
Michael
#28
I think this might be EXACTLY what the OP (and others?) are looking for:
1999-2011 F&R FORD F250/F350/EXCURSION with 2wd Independent, Single Rear Wheel 3.5" Rear Axle 4" up 4" down, 8" travel, replaces Factory Coil springs, Complete with Plug & PlayShip Raw unless upgraded to Powdercoat
Stock height when the Mrs. is on board OR 4" lift when rolling with the big dogs on the block... Complete and 'bolt-on' this seems waaaaay easier and maybe cheaper than a late-model conversion!
#29
full traction suspension is the one im going with. i just got off the phone with the Guys from there. They knew it all work with the best coilovers, and were way cool,and there price wasnt bad. considering coilovers cost about 1600 or more and there full system was about 5,000 or you could even split it up and just buy the front and set up the rear with deavers or whatever your needs are.Full-Traction Suspension Ford F-250 Super Duty 2000-2004 Super Duty 4wd Pickup 4-Link ICG Coilover Conversion System
