Ford Aerostar Front CV Bolt Size
97 AWD 4.0L Ford Aerostar CV Bolt (T45 Head)
If anyone is wondering, it looks like an M8 x 1.25 works best in the Aerostar, despite being told by ford its a 5/16x18
The length is 65mm (just over 2.5in).
I was able to get 4 of 6 bolts into the CV where it joins with the transmission. No issues so far on the highway. I also added a bit of blue loctite to the threads to prevent this from happening again.
Well, hopefully, only the bolts were damaged, and the threads in the flange are still intact.
Also, I note that the front axle flanges that connect to the CV shafts on my 1990 model have only 4 bolts, and your 97 model have 6.
Maybe you already know, you should use thread locker on the bolts to prevent this from happening again.
I was driving at about 70-75km/h and accidentally hit Overdrive Off. I guess the sudden shift in gear sheared the last bolts that were still attached. I think the others backed themselves out over time.
However, the passenger side looks fine.
Here's what it looked like:
1997 ford Aerostar 4.0 AWD passenger side cv axle screws worked out and axle tore up.
i got a new axle but am missing the bolts and I’m thinking another piece?
ive circled what I think is missing from the complete drivers sideif you could tell me what it’s actually called. Thanks!
gator1gear
12-23-2009 05:08 PM
scottlane
04-04-2007 07:06 PM
