V10 vs. 460 vs. PSD
I have an 04' F250 Lariat Supercab Short bed 4x4. I went down to Tampa last night to pick up my fifth wheel. On the way there I averaged 15.6 mpg between 70-75 mph. The fifth wheel is 8000 lbs and 31ft long. On the way back I averaged 9.7 mpg but got as high as 11.5 mpg. I almost didn't know the weight was there. It had plenty of power. I left the truck in overdrive and it never searched for gears or warmed up. I kept it between 65-70 mph. The power seems really good.
ghunt- I have absolutely no idea! I think it's the only one ever built that gets over 10MPG. Auto trans, 4x4, with the air blowing 14 mpg empty on the highway, same as my old 351, manual, 4x4, no A/C did. It's got the 3.73 gears in it, I wonder if that has anything to do with it? Hate to sell it just for that reason alone, but with 2 kiddos now space is getting cramped inside the super cab.
It's interesting. Trailer Life did a comparison of some heavy pickups last spring ('08 models). They were towing an equal load with all of them (8000 I think). They actually picked the V-10 over the 6.4L PSD for towing, although they did say that if the PSD had the correct gearing it would make a huge difference.
With the dismal MPG figures the 6.4 owners are reporting (about eaul to a V-10) I would just get the V-10 and pocket the $6500 it takes to get a PSD .
Well also keep in mind...'96-97 your only choices will be Powerstroke, 460, or 351W.
V10 was not available until '99.
BTW since you ARE looking at used...keep in mind that a truck with a V10, you could probably get a 2003 for around $15,000 or less.
When I was looking at used super duties though...there aren't many with the V10. Lots of Powerstrokes with automatics, and a few V8's here and there.
Originally Posted by superduty4x4
Is this the Stroke or V10?
I would personally go with the 7.3L PSD in a 99.5 or later, but then again I love diesels, so it's and opinion. I would say the v10 is going to be a better and more efficent engines that the 460's. 460's are great engines, but I would pick a 7.3L PSD over any of them. The V10 may have more HP, but the 7.3L PSD has way more torque than a v10, even the new ones. The 7.3L is a rock solid engine and will last for many years of abuse and pulling.
Okay, good info! I'm definitely going to try and find a 96-97 PSD, but if I find a good deal on a V10 I guess I won't totally pass it up. Sounds as if the V10 will get about the same MPG as my 460 as well. I found a real nice 97 F350 4x4 crew cab with the PSD in it not to far from me, but the guy wants $16K for the dang thing! The hunt is on...
