Cold Turbo Sound???
Old 10-22-2007, 11:08 AM
StrokeThis96's Avatar
StrokeThis96
StrokeThis96 is offline
Cold Turbo Sound???
I started my 96 PSD this morning at about 34 degrees. I let it warm up for about 15-20 mins. when i took off the turbo and exhaust pipe were makin a wierd sound, almost like there was something stuck in the pipe. wasnt a whistle like normally on my straight pipe, but more of a blowing sound like an air compressor valve being opened. when i was goin about 25mph it was doin same thing and untill i stepped on it a little more the turbo made the normal whistle sound like normally it does but after i let off it started to whoooosh again. is it a problem with my hpop to the turbo or is it my ebpv??? or is it another problem??
Old 10-22-2007, 11:14 AM
250turbo's Avatar
250turbo
250turbo is offline
i bet it is your ebpv.
Old 10-22-2007, 11:18 AM
plowhand's Avatar
plowhand
plowhand is offline
Playing in the Dirt
It's your ebpv. Just unplug it and forget about it. It's a two wire plug screwed to the base of the turbo.
Old 10-22-2007, 11:19 AM
MADVAN's Avatar
MADVAN
MADVAN is offline
X2
Bill
Old 10-22-2007, 02:13 PM
RÖENTGEEP's Avatar
RÖENTGEEP
RÖENTGEEP is offline
FOREIGN GURU
Arrow
Rigth here:
Old 10-22-2007, 03:59 PM
WALJON's Avatar
WALJON
WALJON is offline
HA HA I had the same noise, even louder when I put on the AFE ,now that I unpluged the ebpv noise is gone
Old 11-30-2007, 03:06 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
this is the EPBV
Old 11-30-2007, 03:12 PM
hoodjason's Avatar
hoodjason
hoodjason is offline
What does EPBV stand for and what does it do? I have the same problem.
Old 11-30-2007, 03:42 PM
Lead Head's Avatar
Lead Head
Lead Head is offline
Its not a problem, its a built in valve to increase EGTs at idle/low speed to warm the engine up faster, they generally work, but can get annoying like that
Old 11-30-2007, 03:54 PM
plowhand's Avatar
plowhand
plowhand is offline
Playing in the Dirt
Like Lead Head said. EBPV = Exhaust Back Pressure Valve
Old 11-30-2007, 06:03 PM
Flea's Avatar
Flea
Flea is offline
So, why unplug it if the trucks operate better at a hotter temp?
Uh, thought coming ... you guys probably don't live in the cold areas?
I hear it only in the AM and then it goes away. The more heat I can get the better to start burning veggie.
Old 11-30-2007, 06:06 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Exclamation
I have read that the EBPV was a wasting time engineers. Most people has it unplugged and no any problems. And other has gutted it for always.
Old 11-30-2007, 06:07 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
But you also can canvert it to a exhaust brake, and works very well and cheap.
Old 11-30-2007, 07:05 PM
glasseater's Avatar
glasseater
glasseater is offline
it barely does anything... it's been in the 20s and under already here.. with mine unplugged it warms up just the same as it always did....
Old 11-30-2007, 09:02 PM
tjbeggs's Avatar
tjbeggs
tjbeggs is offline
The valve does very little of what it was designed to do. If it malfunctions and stays closed it will cause low power and high EGT which could hurt the engine and turbo. The valve only aids in cold start up warming not operating temps.
