Go Back   Ford Truck Enthusiasts Forums > Diesel > 2003 - 2007 6.0L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
2003 - 2007 6.0L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 10-21-2007, 01:58 AM
secakc secakc is offline
secakc is starting off with a positive reputation.
Reason for EGR cooler leaks
I recently had my EGR cooler replaced at the dealership and was later talking to a non-dealer mechanic who works on a lot of 6.0's. He told me he recently spoke to a Ford rep who said the reason the EGR coolers go out so often is b/c the oil coolers get pluged up with sand, which is the real culprit. This is caused by the blocks not being cleaned of sand very well when they were fabricated. So, because the coolant flow is limited it heats up too high and causes the leak. So, he says if you don't change the oil coolers you don't get to the core of the problem. Any thoughts out there on this?
  #2 (permalink)
Old 10-21-2007, 02:01 AM
doubledee715's Avatar
doubledee715 doubledee715 is offline
doubledee715 is starting off with a positive reputation.
makes sense. That's been discussed a lot in the 6.0 forums. That's why Im installing the dieselsite colant filter next month.
__________________
David, 2003 f250 centennial edition, afe, arp, itp, innovative tunes, 4" straight pipe, dieselsite coolant filter, blocked off egr cooler, quadzilla commander w/pillar mount(pos), 4.5" lift, f350 rear blocks, bilstein 5100's, 20/9 kmc hoss, 35/12.5 toyo mt, tinted tail lights, 35% front window tint..
  #3 (permalink)
Old 10-21-2007, 02:06 AM
rollerstud98 rollerstud98 is offline
rollerstud98 is gaining momentum as a positive member of FTE.
does ford check this on all the trucks coming in with egr cooler failures?
  #4 (permalink)
Old 10-21-2007, 02:39 AM
check what? the oil cooler? Some might, some might not. I've read posts of guys having only the egr cooler replaced and posts of both being replaced.
__________________
  #5 (permalink)
Old 10-21-2007, 05:38 AM
LvTitan LvTitan is offline
LvTitan is starting off with a positive reputation.
yes the sand has been known to be a culprit. not only could it plug the cooler, but the sand is abrasive, and is basically "extrude honing" your egr cooler and everything else in your engine.
the coolant filter is a necessity i believe.
another reason for egr failure has been that the high heat of the exhaust gas has actually melted the solder connections on the egr cooler !!
__________________
04 6oh... that's where the money went.
  #6 (permalink)
Old 10-21-2007, 01:12 PM
RickF350's Avatar
RickF350 RickF350 is online now
RickF350 is starting off with a positive reputation.
Due to a warped bed plate at around 10k miles Ford replaced the engine (short block) in my truck . So would there be any sand left in a factory rebuilt engine?
__________________
05 F350 XLT SC LB SRW 6.0L PSD
04 RX-8 Touring 1.3L rotary
03 KTM 525 EXC
  #7 (permalink)
Old 10-21-2007, 06:54 PM
Quote:
Im not 100%, but I would assume. Coolant filter is good insurance either way.
__________________
  #8 (permalink)
Old 10-22-2007, 06:46 AM
npccpartsman's Avatar
npccpartsman npccpartsman is offline
npccpartsman has a very good reputation on FTE. npccpartsman has a very good reputation on FTE. npccpartsman has a very good reputation on FTE.
Most good ford tech's will change the engine oil cooler along with the EGR cooler. Ford even sells them together as a kit so that in itself should say something. A coolant filter is a worthwhile investment in ANY case at ANY mileage as the casting sand can be trapped in lots of nooks and crannies in the block and come out at any time.
__________________
Ford Makes It, International Shakes It, Full Force Fuels It, River City Turbo Spools It, ID Tunes It, and Trucks Unlimited keeps her Rockin the Road with 500+ BADASS Ponies
  #9 (permalink)
Old 10-22-2007, 08:11 AM
Quote:
After further investigation I've been told that Ford may NOT sell these together as a kit and it may be an EBay thing. If I can find the part# for the kit as posted I'll double check and make sure it's correct. Sorry for any inconvenience it might cause.
__________________
  #10 (permalink)
Old 10-11-2009, 09:42 AM
md07superduty md07superduty is offline
md07superduty is starting off with a positive reputation.
is there a tsb on checking the oil cooler
  #11 (permalink)
Old 10-11-2009, 10:12 AM
curtishague curtishague is offline
curtishague is starting off with a positive reputation.
if your rad fluid level gets low this can over heat the egr valve becuse its not getting flow, then it metls, then the truck will bypass it and coolent will be introduced into the motor. this will usally produce a front end vibration when you step on the throtle, and will defenitly caus white smoke to billow out of the pipe. a bad thing. limp it to a garage
  #12 (permalink)
Old 10-11-2009, 10:23 AM
Check out this thread: http://www.ford-trucks.com/forums/87...questions.html
__________________
  #13 (permalink)
Old 10-11-2009, 10:25 AM
Quote:
ummmmmmmmmm NO. I think you have your systems a little confused. Perhaps you mean the EGR cooler??
__________________
  #14 (permalink)
Old 10-11-2009, 10:27 AM
Quote:
I don't know about a TSB, but the oil cooler is considered plugged/failed when the engine oil temperature and engine coolant temperature are 15* different.
__________________
  #15 (permalink)
Old 10-11-2009, 10:41 AM
69cj 69cj is offline
69cj has a good reputation on FTE. 69cj has a good reputation on FTE.
In the normal sequence of things the EGR cooler is after the oil cooler. When the oil cooler plugs up or gets restricted, it restricts the flow of water to the EGR cooler. The solder seams then start to fail in the EGR cooler. There have been instances of the oil cooler leaking but the 1st scenario above seems to be the norm. You can also get a leak at the EGR cooler hose but this is less detrmental to the system as a whole and can be changed without disassembling the top of the engine.
__________________
"05 F-250, 6.0, CC, LB, 3.73, Lariet, with coolant filter and Bilstein shocks, Magnefine p.s. filter, S. Ca.
"69 Mustang, Mach 1, 428 CJ, Ram Air, Stock
"71 Triumph Trident
2007 Thor Jazz 5er, 11k, 31'
173rd Abn.
Tags
2004 , 2008 , change , cooler , coolers , egr , f250 , f350 , failed , ford , oil , supercharger , symptoms , truck , works
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
