Location of FE 352 serial number on 66 F100
Hi folks. I've searched and found lots of references to casting numbers.What I have not found is a reference to where the engine serial number is located.I need to be able to show a number when taking the truck to register it. If there isn't one I will have to stamp one on the block somewhere!
Fords thru the late 1940's were registered by a serial number (aka engine number), originally stamped in several places on engine, hogshead and frame.
Because engines were frequently changed, and then the serial number wouldn't match, beginning in the late 1940's, a Vehicle ID Number was initiated. The entire vehicle is numbered by the VIN, not just the engine.
Why Ford of Australia would be different is unknown to me.
Thanks to everyone for the info. As it stands here, when registering a vehicle which has been unregistered for more than 3 months, the vehicle has to be presented to a registration branch. They view the chassis No / Vin and the engine number. Though the numbers don't have to match there must be both. Certainly on the first Falcons here around 1960 there was an engine number on the left rear of the block near the oil pressure switch.A different prefix depending on engine size. Around the late 60s/early 70s , the engine number was also the chassis number. More recently the last part of the Vin is also the engine number. Though the engine can be changed over the years,
generally the letters in the engine number and Vin will remain the same.The FE blocks were all imported before the engine number rules were in force.I've spoken to someone here who had a 63' 390Galaxie. They had to stamp an engine number on it before registering it in recent years. Way back I guess it didn't matter.
Cheers.
Cheers.
Greetings from the US
Lg2008
03-05-2016 02:59 PM
Bill in Bama
11-19-2015 06:13 PM
twinzilla
12-01-2011 09:32 PM
