Go Back   Ford Truck Enthusiasts Forums > Misc. > Air Intakes, Air Filters & Ram Air
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 10-09-2007, 09:48 PM
bearster18 bearster18 is offline
1992 Ford F-150
bearster18 is starting off with a positive reputation.
Better designed air intake for 85 5.0 efi truck
Hey guys are there any other air intakes off other trucks that will swap onto this 85 F-150 with a efi 5.0? I hate how it puts the air box on the valve cover and I want to see if there is anyway to get rid of it?
  #2 (permalink)
Old 10-13-2007, 11:51 AM
blue beast's Avatar
blue beast blue beast is offline
Garage is empty, add now
blue beast is gaining momentum as a positive member of FTE.blue beast is gaining momentum as a positive member of FTE.
There is a mod somewhere that uses a K&N filter from something that has two intake hoses I think a jap car. You have to put pvc in the stock intake tubes then the pvc goes inside the mounting flange for the k&N. You cut the pvc to make the end of the filter almost touch the fender, Then build a panel to keep motor heat away from it and pipe in cold air from the rad support. I'm sure the catalog will show the filter I mean or you could go with two seperate ones and do the same thing, But the dual tube one has alot of surface area plus a input for the crankcase breather deal.
__________________
86 fs bronco 302 auto 33x12.50 at rusty but trusty!
91 ford probe lx mtx The mighty vulcan 3.0
Before posting fuel related problems Run a couple of bottles of dedicated gas line dryer through IT!!
Tags
50, air, dual, efi, f150, intake
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
