blue beast |
10-13-2007 11:51 AM |
There is a mod somewhere that uses a K&N filter from something that has two intake hoses I think a jap car. You have to put pvc in the stock intake tubes then the pvc goes inside the mounting flange for the k&N. You cut the pvc to make the end of the filter almost touch the fender, Then build a panel to keep motor heat away from it and pipe in cold air from the rad support. I'm sure the catalog will show the filter I mean or you could go with two seperate ones and do the same thing, But the dual tube one has alot of surface area plus a input for the crankcase breather deal.
