South Carolina Chapter Join Chapter, Leader: SC_Hoaty
2004 F250 tire size and swaying????
Old 10-02-2007, 03:35 PM
Hardrock_F250's Avatar
Hardrock_F250
Hardrock_F250 is offline
I have searched for this info but no luck yet. I am going to order new tires for my 2004 F250 w6.0 FX4. I am looking at the Goodyear Silent Armor 285/75R16 or the 305/70R16 tires load range "E". I am concerned about swaying with the 305/70R16 tires, on stock rims, if I am loaded or pulling a trailer with upto 12,000Lbs. These tire will hold 3,525 Lbs at 65PSI, and the 285/75R16 will hold 3,750Lbs at 80 PSI.
Is there anyone here that is running the 305/70R16 on thier truck and hauls a load with them? Is there a problem with swaying, because of having a max of 65 PSI rating?
I was wanting the 285/75R16 but if I can get one inch wider with the 305/70R16, you know this might help me from bogging down so much in dirt.
Thanks for the help.
Ron
Old 10-02-2007, 03:43 PM
Hardrock_F250
Smile
Thanks for the info.
Later
Ron
Old 10-02-2007, 03:59 PM
FTE Trigger's Avatar
FTE Trigger
FTE Trigger is offline
You have 16" tires on a F250? IMHO, I think you may have some xtra roll going into and coming out of turns and banks, but I believe you should do well on straight runs of road.
wreedZ71
2004 - 2008 F150
15
05-14-2009 07:33 AM
78F150RangerXLT
03-22-2009 01:56 PM
kdc642
1997 - 2003 F150
11-30-2007 08:34 AM
The67Beast
Offroad & 4x4
18
11-08-2007 08:31 AM
Quick Reply: 2004 F250 tire size and swaying????
