towing in overdrive
towing in overdrive
I just returned from a 350 mile trip towing my 27 ft travel trailer with my 06 screw 4x4. I tried towing in o/d but it rarely shifted into o/d and if it did shift it did not stay so I turned it off so it would not shift back and forth. I ran aorund 65 mph at 2500 rpm and got around 8 mpg. Is this normal? My Yukon XL can tow in o/d and runs around 2000 rpm and gets 10-12 mpg.
My dad's 04 shifts in and out of overdrive with the slightest hill when he pull his 7K lb camper, so he leaves it out of OD, and only puts it in when the roads are flat and he's going a pretty good speed.(doesn't want the engine driving at 2,500 rpm).
We both fine a difference when towing with OD off. It appears the shift points are a little different, and it seems to pull better. There are other people on here that have said the same thing.
Even with no OD, he gets about 10 mpg. Sometimes a little better with some use of OD(11mpgs), or just a little worst with no OD and a LOT of hills(9mpg).
LarenceF
08-04-2010 01:58 AM
429law
05-04-2010 08:03 PM
ExcellentRed
02-07-2004 11:25 PM
