53 Merc Crankshaft Question
Rod
I can't make out anything in the little pix.
If you're talking about what looks to be chunks broken off the cornors of the throws, thats normal. I don't think I've see a cast flathead crank without chunks missing.
The best way to check a crank is to hold it up from the end with two fingers and lightly tap a counterweight with a hammer. You should get a clear bell like tone.
I just tore down a 53 Merc Flathead I picked up in Idaho last week and noticed that spot on the crank. I have never seen a spot like that on any other crank before, I'm just curious what caused it. I plan to run it, it's only turned down .010 on the Rod and Main Brearings.
thanks for your repiles !!!
Rocketman55
07-21-2013 11:06 PM
ocbp1981
07-17-2011 11:07 AM
jeem
31
06-30-2006 10:48 AM
