tons of pm's on my 10k
#47
#49
Joe,
Is there a particular order to how you gang the resitors? From the ICP side, is it the 10k and then the 5.6, or is it the 5.6 first and then the 10? It seems to me that it may make a difference based off his results. Also, is there a particular direction for the bands on the resistors? In using capacitors for audio systems I know it made no difference to which end (multi directional) was plugged to the speaker lead, but does it make a difference here?
#51
Originally Posted by andywe
Joe,
-James
#53
Thanks for the reply. Actually when I did the 10K I did it the old way by pulling the connector out and inserting the two ends of the 10K resistor. I then put a heat shrink over the exposed wires and it worked great!
When I picked up the 4.6 resistor instead of cutting into my wire as you did, I twisted one wire of the 4.6 on one side of the 10K and one on the other side as a temporary trail to see if I liked the 14.6 K mod. I don't see how that would make a difference but maybe it would.
Justin
Justin
#55
#56
justin, hook the resistors up as shown in the pic and it will feel much better then your
current setup .........
10-4. I did the "Jump" because I placed the remaing pkg. of the 10K some place safe when I did the 10K mod. Problem is I can't find the safe place. Which means I need to make a trip to Radio Shack.
Thanks for your help.
#58
#59
