How to Make Bio Diesel
OK so i am wondering if it is possible to make or brew your own biodiesel (science fair). I need to be able to brew my own biodiesel at home because i am not going to spend 4 grand to convert my truck over to run on biodiesel. I am just going to test the effects of biodiesel vs regualr diesel. EGT's, MPG. If it is possible to make biodiesel using home materials plus the cost of buying vegatable oil or any other kind of oil then please tell me how or give me a website that has specific directions. Also how safe is it to make biodiesel. I mean i have read things that say that without removing chemicals from the oil that act as delubricants you can burn injectors up. SO if any of you make biodiesel at your home and then dump it in the tank (if its possible) could you please make a direction write up for me. Then if it would be ok to site you in my reference page.
THanks Adam
THanks Adam
Go to this page http://www.biodieselcommunity.org for instructions.
Are you talking about converting to straight vegetable oil (SVO)? Your statement is very confusing. Biodiesel requires no "conversion" for the vehicle.
If you mean to you personally, physically, making the fuel, you have to know what you are doing, and it's very similar to high school chemistry class.
If you mean to your vehicle, that all depends on the quality of your fuel.
This makes no sense. When you're making biodiesel, you do a chemical reaction that separates out the glycerin from the vegetable oil molecule. Biodiesel is used as a lubricity additive, it has such a high lubricity.
There are several methods ranging from water washes to "dry washing" with Magnesol. Dry washing produces the best result with fewest problems.
The best source here is FABMANDELUX
archangel
Bio-diesel, Propane & Alternative Diesel Engine Fuels
29
04-18-2010 08:45 PM
khadma
17
06-14-2009 11:14 PM
floridadude
35
08-10-2008 09:36 PM
turboman24
09-13-2007 10:15 AM
