can anyone tell me how to remove the steering shaft from gearbox
I picked up this steering gearbox from my local wrecking yard (mines shot) and was wondering how the steering column shaft comes off? any input is appreciated
cool I can handle that, only it raises the question....this box is from an automatic tranny truck and mine is a manuel tranny. Just wondering if the steering shafts are the same.....in other words if they are the same do I realy need to do all that or just chhange everything shown in the pic. always looking for the easy way out
So I guess I was a little overconfidant, I cant figure it out. I started to take er apart and cant figure it out. anyone have a tech data sheet or service manual page scanned into thier puter. I need some guidance.
Thanks
Thanks
pretty simple as there,s not much to em. pull bottom and side covers off and your looking at two gears- side shaft and steering shaft. once the the covers are removed the whole thing should come apart. why are you tearing this one down? the steering shaft gear is a press fit.also don,t disgard the thin shims from the bottom plate cover as these are actualy shims to adjust tightness in shaft movement.by the way my 59 has a 15" 60's style wheel- chrome 3 spoke- you know the style and no problem steering ever at least my arms have not fallin off yet. I,m going to replace it with a mohogany one of same size- just my personal taste- but your idea sounds solid to me. Mark
Thanks Mark,
I was just going to replace this junk yard box with mine, the splines on my column are'nt as messed up as the splines on this shaft so I was going to see bout replacing steering shafts too. but maybee not.
