Stuck real leaf springs
Once again rust is kicking my butt. I'm trying to get the rear end off of my 56,and the studs are stuck hard in the frame spring brackets ... any suggestions short of dynamite? I've been keeping them soaked in liquid wrench and smack them with a hammer and punch every chance I get.
Originally Posted by uk1050
ive been working on a jeep and had the same problem, i finally just cut the bolt with a cutoff wheel.
It may be too early in the morning for my last gray cell to work. Are you talking about the U-bolts that secure springs to the axle? What studs?
I'm with Randy Jack on this one. There are no studs beside myself (Sorry, I saw it coming)? If it's the U bolt your talking that holds the rear end to the leaf springs I know my friend who works at a suspension shop uses Transmission fluid. Soak the rusted parts good over nite. The tranny oil penetrates the rust really nice and then use an impact wrench. If it's the shackle, use Randy's advice. The rivots are a pain to get out.
One parts catalog calls them studs, another calls them pins ... to use a technical description, they are the thingies with the grease fittings on the end that go through the eyes on the springs to mount them to the truck. I decided to just knock the rivets out of the frame mounts and pulled the entire rear assembly off. Now that its off maybe I can figure out how to get them loose. I know that when I put it back together a little anti-sieze compound is going on them.
Tony,
I haven't seen it mention yet so I thought I better chime in here and post the only tried and true method to remove the pins and springs. I think 99% of us here have used one form of this method with great success.
OK, first things first.....
1. find an old sailor and get a few lessons on cussing. You will need lots of "salty" language. After you get comfy with spitting out your new vocabulary in loud long 3 to 5 minute rants, then you are ready for the next step.
2. look around in and under your truck until you find some decent rusty, scaly dust. Gather the dust until you have at least a cup of it. Now, holding first one eye open and then the other get a handful of the scaly dust and rub it into your eyes generously.
3. Once both eyes are stinging and watering without and end in sight. Grab a large wood rasp and drag it across the back of your hand and knuckles
4. Take your large hammer (BFH) hold it tightly, make a fist with your other hand and repeatedly smash the hammer into your fist (prefereably on the knuckle of your index finger that you just pulled the rasp across)
5. just for good measure, while laying under your truck try sitting up several times so as to smash your forehead into a crossmember (preferrably a scaly, rusty, dusty section)
6. Now that your hands are bloody, knuckles are sore, head hurts, eyes are blurry, go get yourself a frosty beverage
7. Repeat steps 1-6 (In severe cases you may proceed directly to step 6)
Good luck with the pins. They can be a real pain. You might try adding and/or taking weight off the springs. If they are really worn and grooved you might have to find just the right spot to get them to move. I have heard that some people have had luck using a dent puller threaded into the grease fitting hole. I did mine with the bed still on the truck. Someone had cut holes in my front x-member for access. I used a long (16") piece of 1/2" round stock for a punch and beat the tar out of mine to get them out.
Good luck with it
Bobby
Good luck with it
Bobby
The locking pin thingies were easy ... using a 5-pound sledge hammer and a big punch.
Bobby, I've used the technique you mentioned frequently. I think my eyes are grit magnets. I've started wearing my safety glasses any time I get within 15 feet of that truck.
If I can get the u bolts off the leaf springs, I may try the press idea. I hate to cut them off at $8 a piece, but after fighting with them for two days, the money math is starting to get me thinking ... $24 divided by many hours ... I'm working for waaay less than minimum wage
