o2 Sensor question, 99 F250, 5.4
'03 F250 Super Duty 5.4L Triton
I seem to have the same issue. I need to change my O2 sensors but can only find two. Advance Auto tells me i have four and a ford service man said i only have three. But i am only able to find two of them before the cat on the Y Pipe coming from the exhaust manifold. Nothing after.
Can someone help me?
My 05 has 4 O2 sensors. 1 before and after each cat. When the cats are gutted with before and aft sensors you may get a code on the next startup that says something like bank 1 sensor 2 catalyst not efficent. The 02 sensor codes can be reset and will not come back after you run long enough for the truck to adjust to the change
I'm reasonably sure that O2 foolers were plugged in on my '03 5.4, but I'd have to crawl under to confirm, I de-catted it nearly 10 years ago now. Sometimes I have a hard time remembering what I did yesterday .
jonathanpatr
21
12-27-2016 10:13 AM
